1st: Dont listen to the so called gurus at FixYa. As the guru there was telling me that the frame was glued to the cabinet. If I would have followed his recommendation Id be buying new cabinets as well as a new mounting frame. FixYa should credit me my fee paid.
The solution: For the built-in cabinet AEG microwave oven, it is required to use the AEG mounting kit. The AEG mounting face frame uses for screws, one at each corner concealed by small black plastic caps that blend in perfectly with the contour of the mounting face frame. If you look closely towards the inside of each corner you'll see a very small slot in the cap that will allow you to put a small flat head screw driver into the slot to work the cap out. Once the four caps are removed use a phillips screw driver to remove the screws that fix the mounting face frame to the cabinet.
You should be able to download or order the installation instructions via this site.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
