Sony Toshiba Qosmio F45-AV411 Notebook Logo
Posted on Aug 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i replace a toshiba qosmio f45-av411 lcd
My screen is cracked and needs to be replaced. i know where to buy the screen, i just need to know the steps in the removing the cracked screen from the laptop and putting in the new one. thank you.
Anonymous
Level 3:
  • Sony Master 32,281 Answers
  • Posted on Aug 28, 2009
Anonymous
Sony Master
Level 3:
Answers
32281
Questions
Helped
7913447
Points
102259
You can buy LCD screens on the Internet, I purchase parts from LCD Parts, they also service/repair and have DIY info.
Use this link to their WEB site :-
www.lcdparts.net
Anonymous
Level 3:
President:
  • Master 2,600 Answers
  • Posted on Aug 27, 2009
Anonymous
Master
Level 3:
President:
Answers
2600
Questions
0
Helped
1018132
Points
8362
This for the lcd replacement...regardless of cause this will give you the simple steps.
http://www.laptoprepair101.com/laptop/2007/02/03/repair-notebook-lcd-screen/
Neciforo Llanto
Level 2:
President:
  • Expert 942 Answers
Neciforo Llanto
Expert
Level 2:
President:
Answers
942
Questions
0
Helped
316010
Points
109
You replaced the broken LCD screen in your laptop with a new screen. Does this sound like your problem? Let’s find out what could be wrong and how you can fix it.
First of all, I assume that your new LCD screen is compatible with the old one. Different screens require different video cables. Make sure you new screen is compatible with your laptop.
OK, let’s say you accidentally damaged the LCD screen in your laptop. A part of the screen still works fine but you cannot use it like that so you decided to replace the screen yourself.
Her is some instructions to follow.
Before you start to panic, check all cable connections again. Check connection between the video cable, LCD screen and inverter board. Reconnect cables just in case.
Take a closer look at the connection between the video cable and LCD screen. It’s possible you accidentally pulled the video cable from the connector during the screen installation.
The video cable has to be seated properly, all the way down.
Also, on some older LCD screens there are very thin pins inside the connector. Take a look inside the connector, make sure there are no damaged (bent) pins.
You can straighten bent pins with a very small screwdriver but this procedure requires a lot of patience and concentration.
Fortunately, most newer LCD's have a different type of connector, without fragile pins inside.
OK, you have reseated all connectors and cannot see anything wrong but the new screen still is not working. What’s next?
Remove the new screen and connect the old one. If the old one works properly (except the damaged area) but the new one is dead, apparently the new screen is defective and has to be replaced.
Hopefully it has warranty.
Here’s another scenario. The new screen kinda works. You can see a very faint image but there is no back light.
If that’s the case, disconnect the new screen from the inverter board and plug in the old screen instead, as it shown on the picture below. If the back light inside the old screen lights up, apparently the new screen has defective back light lamp and has to be replaced.
Thanks for using fixya. Hope it is helpful for you.
Good luck
PCmania
  • Neciforo Llanto Aug 28, 2009
    You can buy screen through online you need to visit the ebay site to but it.
    www.ebay.com the online selling website.
Anonymous
Level 3:
  • Master 3,153 Answers
Anonymous
Master
Level 3:
Answers
3153
Questions
Helped
1166319
Points
11010
FRo most laptop parts I tend to use Ebay
The link should take you to a search I already did for your screen
Anonymous
Level 2:
  • Expert 68 Answers
Anonymous
Expert
Level 2:
Answers
68
Questions
0
Helped
13481
Points
177
First remove the battery from te laptop. Locate all the screw covers (in the front side) with the watch maker screen driver. There might be four of them. Once you remove the screw. covers, remove the screws and remove the front bezel. You can now separate eh front bezel. Locate the screen assembly. Remember, there might be laches. So, be careful not to break them. You will see the frame scrwes after this with the vedio cable quite visible. Just remove them to find the invertor. Thats it.. You have removed the LCD screen.
Hope this helps.
Regards,
Hari
Audio driver for high defination bus not installed.
Software should be on http://support.toshiba.com. (Under the tab downloads)
Here is a direct link : http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1754951&rpn=PQF43U&modelFilter=F45-AV411&selCategory=2756709&selFamily=804517
Select the Realtek Audio driver there.
I need to reset the bios on my toshiba qosmio f45-av412 please help1
To reset the BIOS read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Have a Toshiba Qosmio F45-AV411 and downloaded windows 7 last night. worked fine then I put comp in to sleep mode when I tried to turn on today looks like it is booting up and then goes to a black screen...
Try to boot up the computer using safe mode first. Keep on tapping the F8 key the moment you turn on the computer. If your computer wont boot to safe mode then you need to re-install windows 7.
1helpful
Crashed error 03-FFFF-OOOO
if that error occurs while attempting the recovery, typically it indicates a read write error on the hard drive. replace the hard drive and see if the recovery finishes.
(although i have only seen this problem with failing hard drives)
2helpful
2answers
Toshiba qosmio f45-av411 how do i reset to factory settings
There is no magic button that i know of that fixes those faults Returning it to factory defaults doesn;t reinstate broken parts. To me it sounds like a board fault and that some jiggling you did temporarily caused it to make contact for a while. It could be a loose cable connecting the problem components to the main board, it could even be a cracked M/Board. It would have to be opened to check for that. I don't advise you to try it either as many before you have ventured into laptops and never been able to get them back together again.
Putting a new disk in sounds to me to be a waste of money on a machine that has so many problems.
If the unit is so valuable to you I would be biting the bullet and having it repaired properly, not mucking around hoping you get it right by a fluke, that way you will end up spending more thanj $300.
You can buy a new Toshibt Satellite Pro for $400 after cashback. So why persist with a dying machine with no warranty and a 100 problems?
Please rate our help++++Thanks for using FIXYA
DVD drive replace
If its in a desktop ist simple you need to unscrew the back panel and then unscrew the side cd drive panels , remove the IDE cable from Scocket
I want to upgrade the CPU on my Qosmio F45-AV411 from a T5450 1.66 to something "faster/Bigger" is this possible and what would you recommend. THANK YOU
i took a look at that Qosmio F45-AV411 it doesn't seem to be upgrade able to a higher cpu
please check with toshiba on this issue before you go further
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
