AT&T CECT Unlocked i68+ Quadband GSM FM Mobile Phone+Free gift Smartphone Logo
Posted on Aug 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When trying to transfer music, it says my memory is full its not
When i connect the USB and try to transfer music, the computer tells me i need more room on my phone. Am i not using the card storage and only the phone storage? how can i use the memory card?
Anonymous
Level 3:
  • Master 355 Answers
  • Posted on Aug 20, 2009
Anonymous
Master
Level 3:
Answers
355
Questions
11
Helped
145381
Points
1134
Check for Is there any slot for Card Like Micro SD card. In this slot you can insert your micro SD memory card ... Well before doing this you have to buy memory card if it is not given by your mobile..
Regards
How do you get music to save on a new 4gb memory card on a nokia E5 instead of saving in phone memory
Transfer music from a computer
You can use the following methods to transfer music:
• To install Nokia Ovi Player to manage and organize your music files, download
the PC software from www.ovi.com, and follow the instructions.
• To view your device on a computer as a mass memory device where you can
transfer any data files, make the connection with a compatible USB data cable
or Bluetooth connectivity. If you are using a USB data cable, select Mass
storage as the USB connection mode. A compatible memory card must be
inserted in the device.
• To synchronize music with Windows Media Player, connect a compatible USB
data cable, and select PC Suite as the USB connection mode. A compatible
memory card must be inserted in the device.
To change the default USB connection mode, select Menu > Ctrl. panel >
Connectivity > USB and USB connection mode.
I hope this information will be helpful. Thank you for using FixYa!
3helpful
I want to download music using my usb
Hi,you can transfer music to nokia 5800 from your computer(pc or mac). There are different ways of transferring music.if you have a PC, you can use PC Suite to transfer music files.the nice software that comes with the phone. If you have a Mac, you can use Nokia Multimedia Transfer (free download) and sync it with your iTunes.
how to put songs on nokia 5800-nokia pc suite
To transfer music as data files, make the connection with a compatible USB data cable. You also need to have a compatible memory card inserted in the device. View your nokia 5800 on a computer as a mass memory device. follows these steps: firstly, connect nokia 5800 with computer via USB data cable. then select Mass storage as the connection mode. A compatible memory card must be inserted in the device. then view the device from the computer file manager as a mass memory device. now you can fansfer the music files. after transferring songs, you can close the connection by remove the USB device safely from your computer.
Hope it helped.
2helpful
2answers
I tried downloading mp3 music on my nokia 5230 it doesnt work
you might want to check your java scripts, also try master reset see link below --> discussions.europe.nokia.com/.../Nokia-Nuron-5230-how-to-master-reset/m-p/773627
I cant get music to transfer to my LG 8575 samba
Music can be transferred to this phone using a USB cable or through Bluetooth. To transfer your song using USB cable,
  1. You will have to connect your phone to a computer,
  2. Be sure to have the USB cable of your phone, then you connect it to the computer,
  3. Then you click on open file to view folder as soon as the Auto play comes up on the screen of your computer,
  4. That way a page will open with the files on your phone,
  5. Go to the music you want to transfer to the phone, then you right click on it and copy the music,
  6. Go to the page where you have your music and paste it there,
  7. That way your music will be on the phone.
To transfer through Bluetooth, ensure the phone you are trying to transfer music from has bluetooth on it. Ensure the bluetooth is on, then you follow the steps below:
  1. Go to your phones menu,
  2. Select the settings, and turn on your bluetooth from there,
  3. Then you go to the phone you want to transfer the song from,
  4. Select send via bluetooth,
  5. It will search for the available bluetooth that is turned on,
  6. Once it finds yours, select it and the music will attempt to be sent to your phone,
  7. Accept it on your LG phone, then a page will load,
  8. That way the music will be sent to your phone.
Be sure that your phone has a large memory that can receive the file, be sure also that the musics size is not larger that 7mb, if not, it might not load on your phone and says memory full. If your phone allows memory card, the moment you transfer the music to your phone, then you browse it out from your multimedia and transfer it to your memory card, to avoid the memory full error from coming up.
Hope this was helpful. Thank You for using FixYa!!
I have recently purchased a 4GB USB drive to transfer music etc to my Xbox 360. However, when I format it with my Xbox, and then put it back into my laptop, it tells me that there is no memory left. ...
you cant transfer music all you can do is connect it to xbox go to music blade and play it if you transfer it it ends up corrupt and harddrive consuming
I know its a silly question but can anyone please tell me the step-by-step process to transfer songs to my sansa c150 MP3 player......... Thanks
  • Step 1:Free a USB port on your desktop computer. Now, grab the USB cable for your SanDisk Sansa MP3 player and connect the player to your computer.
  • Step 2:Wait for your computer to find and recognize the player. This may take a few moments. Once you receive a confirmation message, open your computer and scan the icons for the SanDisk MP3 player.
  • Step 3:Open the SanDisk Sansa MP3 player on your computer. The music files that you currently have saved to the player’s memory are displayed.
  • Step 4:Open a folder containing music files that is stored in your desktop computer’s memory. Scan the files for songs that you want to transfer to the SanDisk Sansa MP3 player.
  • Step 5:Left-click on a song file and drag to the SanDisk Sansa window. Drop the file and let your computer complete the transfer. The transferred file appears at the bottom of your music list.
  • Step 6:Unplug your SanDisk Sansa player from your computer. Turn the player on and allow the file transfer to update to the internal memory of the MP3 player.
Tips & Warnings
  • When properly connected, the SanDisk Sansa MP3 player displays a USB Connected message on its LCD screen.
  • The music files in the SanDisk Sansa MP3 player will have different icons next to their filenames which will tell the file type at a glance (MPEG, MPEG layer 3 or WMA, for example).
  • Some songs feature copyright protection which may interfere with your ability to transfer music to the SanDisk Sansa MP3 player.
17helpful
2answers
LG Viewty KU990 pc sync
Do you mean you want to tranfer files or music files from your computer to your phone so you can enjoy music on your device? If so let me tell you that BLUETHOOTH or the SOFTWARE CD are not the best or fastest ways to sync or transfer files from your computer to your phone or vise versa, so Im going to tell you the safest, fastest, and Easiest way to do it, using your USB ,but it may require you to change settings manually on your device first. Make sure you have a Memory card,
Choose settings for USB connections
1.Find "USB connection mo..."
  • Press the menu icon.
  • Press the fourth tab.
  • Press Phone settings.
  • Press Connectivity.
  • Press USB connection mo.... 2.Select setting
  • Press Mass storage
  • Press OK. 3.Exit
    Once you've done this and have your memory in your device, Open the MY COMPUTER folder in your computer and connect your device to your computer using the USB cord, a new Icon will appear containing the folders from your device's memory card, that way you will easily be able to transfer files back and forth without the NEED of any sofware Cd's or use slow Bluethoot.
    And Welcome to the Viewty Family! Enjoy...!
  • 0helpful
    Lg ku990
    Do you mean you want to tranfer audio files or music files from your computer to your phone so you can enjoy music on your device? If so let me tell you that BLUETHOOTH or the SOFTWARE CD are not the best or fastest ways to sync or transfer files from your computer to your phone or vise versa, so Im going to tell you the safest, fastest, and Easiest way to do it, using your USB ,but it may require you to change settings manually on your device first. Make sure you have a Memory card,
  • Press OK. 3.Exit
  • 0helpful
    3answers
    Getting music on to my KG800 mobile phone
    I had the same thing with my KF510 but I don't know if it will be the same with your phone. When you connect the phone via the USB cable you will see two removable drives in My Computer ( I have Windows XP) one is the phones internal memory the other is the memory stick.
    Drag and drop the MP3 files onto the memory stick - BUT - make sure you drag the files onto a folder in the drive not just onto the drive icon as if they are not in a folder ( on mine the folder is called Sounds) the phone won't find them.
    To see the folders on the drive icon just double click the icon or right click - explore.
    Hope this helps you.
    Top AT&T Cell Phones Experts
    ZJ Limited
    ZJ Limited
    Sean Wright
    Sean Wright
    ADMIN Andrew
    ADMIN Andrew
    Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
