SOURCE: need battery wiring diagram for 1987 ezgo golf cart
Tell me what cart you have and i can help. Not all carts get wired up the same way as this link demonstrates. In the pix pay close attention to how battery one gets hooked up as this sets the pattern
http://www.updateyourdriver.com/driver/?t202id=211793&t202kw=webcam&gclid=COTM4t-ZsJwCFQxM5QodWjoflQ
SOURCE: Electric Golf cart only shutters and inches forward
so many possibilities...
does it roll fairly freely? (checking to see if the brakes or rearend seized up)
Are there any "bad" sounds like things grinding? (Connection between Motor and rearend, axle splines...)
If all that is solid, it is likely in the controller.... (it takes a solid charge right... No bad batteries in there or loose connection? might want to check all the battery connections to make sure none are burnt...)
1997.. does it have the electonic speed control by that year? the other possibilty is that the accelerator is not working corectly. they used a resistor system on old ones that has contactors that would get worn out.... Newer ones control a potentiometer(sp) that controlled the speed.
Only a few real components to check, but if you are not mechanically and electically inclined, could be tough to isolate.
peace,
SOURCE: batteries run out of power too quick, what is my problem
The voltage should be above 37 volts if you have 6 volt batteries. This must be measured under load. A simple voltage check is useless. If the batteries are over 6 years old, they are probably in need of replacement.
SOURCE: 1987 EzGo Gas power Golf Cart will not run. It has gas and new battery
You have this in the wrong product category.
SOURCE: Can I leave my 2004 ezgo golf cart charger plugged
never leave charging all the time you want to charge it every 6 hrs of running time to let your batterys cycle down. it would be the same if you charge your cell phone everytime you make a call if you cant keep track of it get a state of charge its a volt metter like a gas gauge for the batterys if you do it my way you will get more run time and your batterys will last around 10 yrs if keep doing it your way them about a couple yrs on them
