SOURCE: Roland SPD-S Flash card error
The card I have always been using is now also suddenly giving this message. I found an old SanDisk 16MB and a 1GB SanDisk that works perfectly in my Boss 864 and they also give the same message. Trying to go into formatting brings the message "no card!"
SOURCE: Bought used Roland SPD-11 with
Manuals are here in PDF:
ftp://ftp.roland.co.uk/productsupport/Manuals/
SOURCE: roland Spd-s pad #1 change to different patches when hit
I'm an experienced SPD-S user and there is no option that allows the SPD-S to produce random sounds from the same PAD.
I can think of 3 reasons why this may be:
SOURCE: I have a Roland HP 2e digital piano - Foot pedal problem
The ROLAND pianos USUALLY require that you use a normally closed sustain pedal.
MANY pedals are the opposite and close when pressed. SOMETIMES you can open the pedal and reverse the way the switch works.
SOURCE: Roland Spd-s pads not working
Check for a cracked PCB internally from the two defective pads, or if the wires have detached from the trigger. You may not need parts, but if you do, it really depends on how helpful the Roland distributor in your area is as to whether you will have any luck getting them, or you may have to go trough a local authorized repair shop.
Good luck.
