SOURCE: standard horizon 155c not acquiring signal
If the signal is good statement seems to imply that it is working, perhaps this is my misinterpretation of what you mean by this.
Signal refers to the abi;ity to connect to satellites
4 are requied for triangulation.
If the unit is fully charged and not connecting , then it is quite possible that the unit has a damaged SIIRF chip or whatever chip was used in your model to acquire satellite connection. The cost of repair is costly, it means total replacement of the M/Board.
Never start car with the unit connected into DC car power, spikes will damage the chip
SOURCE: need to install new MMSI number
http://www.raymarine.com/SubmittedFiles/Handbooks/Communications/81231_2www.pdf
Check the instructions on page 61 of the manual (link above)
SOURCE: how to reset mmsi number Raymarine 215
This secret code is for the Raytheon / Raymarine RAY 220 VHF. It may work on other Raytheon/Raymarine radios also.
Here you go:
With the Power OFF, Press and HOLD the FUNC, 16/9 and DSC keys while you power ON. Do not release the keys until you hear the audio BEEP which means your done. Then reprogam your NMSI number as per the manual. Pretty easy, hey?
SOURCE: need to reset the mmsi
Did you ever solve this problem. I have just purchased a little Leisure 17-SL with a fairly new one of theses radios. I have the handbook and discover you can only program the MMSI once and then return to a dealer to clear it!
Many thanks
Steve
http://www.withamweather.co.uk
