Televison & Video Logo
B
Black Black Posted on Sep 27, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an old magnavox model number 22787047 that only gets static. Is there a fix for this? Thank you.
Paul Bade
Level 3:
  • Magnavox Master 1,818 Answers
  • Posted on Sep 27, 2018
Paul Bade
Magnavox Master
Level 3:
Answers
1818
Questions
Helped
574941
Points
5816
If this is an older CRT TV, you probably have no analog TV signal present - most nations have converted to digital TV. In that case, the only way it will work is to get a digital to analog TV adapter box to connect to the antenna or video input terminal.
If it's an AM/FM radio, the bandswitch may have dirty or tarnished contacts. This can usually be fixed by opening the radio and spraying a bit of electrical contact cleaner into the switch (it does not work to spray it on the knob shaft or switch actuator from the outside of the radio; you have to get directly on the contacts inside the switch). The volume control may also be dirty; use cleaner made for electronic volume controls, rheostats or potentiometers. Do not use WD-40 or other solvents; they may dissolve the resistive material and ruin the part.
While you have the radio open, check the AM antenna coil (a black rod or bar about 2-5 inches long with wire wrapped around it. If the black ferrite material is cracked or broken, the antenna will be much less effective, if it works at all. If this is replaced, the AM input transformer will probably have to be retuned for optimum performance. This should be done only with a plastic screwdriver, (metal messes up the tuning and may break the ferrite transformer core). This is best done using a post marker-sweep generator and an oscilloscope.
1 Related Answer
Anonymous
  • 515 Answers
  • Posted on Aug 10, 2008
SOURCE: Magnavox Stylus
We need to know the model number of the CARTRIDGE itself. Doesn't matter what turntable you have. All that matters is what cartridge is mounted on the turntable, so that we can match the correct stylus. The stylus/needle connects to the Cartridge:
As the diagram shows, the stylus mounts to the cartridge, which then mounts to the headshell. This headshell is then connected to the tonearm (tube).
So, if you look at the cartridge you should be able to see the model number. If not, there is no way to match up the stylus, as ther are literally THOUSANDS of styli on the market. I would suggest purchasing a NEW cartridge/stylus combination. The following should fit your model:
UNIVERSAL MOUNT CARTRIDGES
- Davis
DJ Pro Audio
www.djproaudio.com
1helpful
Where can I find a manual for Magnavox radio-phonograph model 1P3753? The one I have will not turn on at all. Not even the radio. I want to attempt to fix it. Thank you.
Hi, there.
I checked for that model number in my Magnavox catalogs and could not locate it. I also went ahead and searched - based on the number - on the Sam's Technical Publishing site that carries user and repair manuals - but no luck. However, you can request the manual through the site to see if it is in stock. I don't work for Sam's, so not advertising. It's the site I have used for locating manuals for the many units I have repaired. Where the pros shop for Photofact manuals Quickfact manuals service...
Is there a way I can fix the low static sound on my Magnavox DVD player
Magnavox tv has loud static - TV - Streaming Video & TVs
www.tomsguide.com/answers/id-2293282/magnavox-loud-static.html
Sep 9, 2014 - After a loud clap of thunder my magnavox tv with built in dvd and vcr developed static sound ... JVC DVD player and Samsung VCR to my new MagnavoxHDMI TV ... Can you connect the cable box with a HDMI cable or component ... and making a loud humming sound how do I fix help · Burning in of static ...
What is that TV Buzzing Noise? - noice fix brokentv ' Ask MetaFilter
ask.metafilter.com/17525/What-is-that-TV-Buzzing-Noise
Apr 14, 2005 - My TV does this annoying buzzing sort of humming noise (vibrating?) ... It especially seems to do it when I have the volume turned down low (or else I just don't notice .... The capacitors in there can store a charge large enough to kill you for 12 hours or more. ... Although, I feel like I hear it more often on DVD.
HOW TO FIX VCR & DVD PLAYERS REVIEW - YouTube
? 9:23
https://www.youtube.com/watch?v=1ggOD7RnMJU
Mar 17, 2013 - Uploaded by Tampatec
HOW TO REPAIR FIX VCR VHS DVD COMBO Easy Quick & Simple COMMON FIXES FOR ... this works ...
Magnavox TV help - ecoustics.com
Hi, i have a blue screen of death, couldn't catch the error code number but it has to do with the CPU not recognizing the BIOS , at this stage i cant boot up at all not with Safe mode either, the...
1) Post the manufacturer name and model number of the Desktop PC.
The model number is on the back next to the Windows product key; or up on the side of the computer tower.
2) Do you know about Anti-Static Precautions?
3) Is the computer dirty inside?
4) Sounds like you may need some Thermal Paste, Q-tips, Isopropyl Alcohol, (Rubbing alcohol), and and old credit card.
Example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3829122&CatId=503
Post back in a Comment.
Regards,
joecoolvette
Had a severe thunderstorm yesterday (7/23/08). Lightening hit the transformer, all power was out for 6 hours. 3 Televisions. 1, hooked up to modem works fine, 1 hooked up to cable reciever only gets static...
Upon researching various websites regarding the Model Number for those 2 televisions that blew out, I found a few other people around the US that had the same problem with similar situations. All involving massive thunderstorm power-outages.
It appears that since out TV's are both 5-6 years old, they are worthless, both covered under homeowners but for almost nothing. It's not worth fixing. So, decided to purchase 2 more lower quality televisions as this will most likely happen again when the next storm hits. Thank god we found out that this is a repeat issue before we purchased a really expensive television.
2answers
Magnabox tv noise flyback transforma
Post the model number of your magnavox and I will post a link where you can get the correct replacement flyback for your model and get free tech support to help you install it.
Replacement or instruction needed to fix T.V. Convergence
The conversion amp ICs. Let me know if you need more info.
1helpful
2answers
Magnavox television stuck in demo mode
My wife somehow put our Magnavox TV into demo mode too...
Plug in the set. With the set ON. Press the volume up (+) AND volume down (-) at the same time.
This worked to get it out of demo mode!
22helpful
5answers
Smart lock access code on tv
A model number for your Magnavox TV would be helpful because the Parental Control Reset procedure varies. There should be a sticker on the back of the TV showing the model number. If you have a newer LCD model, the unlock code is usually 0711. Ignore any "Incorrect" warning and enter 0711 again. Then set or clear the Parental Access Code.
Magnavox Sound
you need to get inside the knob and clean it well with some kind of denatured alcohol. it that did not work, check if you have any loose or cold soldering joints. if that did not help you need to change the knows..good luck
Top Magnavox Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
