SOURCE: 1996 GMC Suburban Rear Heater Core Hose Removal and Installation
if you can get me a picture i can help you out. blue_dragon45801@yahoo
SOURCE: LG dishwasher drain hose
You will have to remove the dishwasher from the cabinet, lay it on it's side, and remove the bottom access cover to get to the end of the hose. (it's usually not as bad as it sounds)
SOURCE: Water in drain pump for ASKO D5122XXL dishwasher
Yes, Asko dishwashers can leave a small amount of water in the sump after a cycle completes. At the beginning of most cycles the sump is pumped and new water added.
SOURCE: Asko 1475 dishwasher - won't wash. Circulation pump?
Check your drain. It is dual purpose. It not only drains but, it also recirculates the water doring the cycles.
SOURCE: The drain pump motor on my ASKO model 1375
Had a similar scenario on my Asko 1325. I simply removed the unit in preparation to chuck it, but once outside decided to check the inside of the pump/impeller and the electrical connections. Found plastic debris in the pump, and wiggled every electrical connector of its attachment and then re-attached it. Tried the Asko-fiasko outside and it worked.
BTW be prepared for an electrical failure/ meltdown as per the following two photos:
