20 Most Recent Asko D1776 Built-in Dishwasher Questions & Answers
F2 flashes, and wll not stop runing. No water in pan. help
Asko D1776... | Answered on Feb 25, 2019
Insufficient water can cause those symptoms
Asko D1776... | Answered on Nov 03, 2017
it's the door switch gone bad or the wire going to it has fallen off.
Asko D1776... | Answered on Jun 07, 2016
The F2 error means the tray underneath the unit has filled with water
please check this solution:
http://www.fixya.com/support/t6078000-f2_error
Il you want to diagnose or repair the nit yourself, I suggest to protect yourself by connecting the unit on a residual-current circuit breaker (RCCB).
Asko D1776... | Answered on Sep 18, 2013
It could be 3-4 things that are causing this issue,first: something got in pump and jammed it,second:pump is not getting power,remove back plate and check wire plug to pump,push it all way in and see what happens,check flood switch it could be defective and is not activating when unit is turned on,check wire plug to flood switch and make sure is all way in,if pump is not humming or do nothing or no sounds at all,than drain pump is bad or not getting current (power)drain pump should run as soon as you turn on unit,you must check Flood Switch,is on drip pan at the middle,it has styrophone in it,be careful or you can get the shock of your life.Good luck.
Asko D1776... | Answered on Apr 12, 2013
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
Check how to remove the control panel: http://www.espares.co.uk/advice/dishwashers/a/3/1287/how-to-replace-a-hotpoint-dishwasher-fascia-p.html
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If there is low pumping or pressure then the spray arms will not turn around to inject with pressure. If so the pump must be checked for clogging.
Asko D1776... | Answered on Oct 25, 2011
Asko D1776 Built-in Dishwasher Logo
78 questions posted
Top Asko Dishwashers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Asko Dishwashers
  • Asko Dishwashers
Most Popular Question
asko dishwasher f2 error flashing
  • Dishwashers
