SOURCE: Fossil watch
I have a Fossil Kaleido that i havent used in some time. I just replaced the batteries in it and the only thing that works is it goes from solid red to hearts..it wont keep time. I only have 2 buttons on the side..one to change the time and one to set to either red or switch back and forth/// PLEASE HELP!! i love this watch
SOURCE: Fossil watch dead
Get battery out again. Clean (scrape) all the battery related contacts using steel needle or small screwdriver. Make sure the battery is not underpowered. Refit the battery keeping the right polarity and set the watch.
Don't forget to rate, please.
1)Get the battery out again and check for power. 1,5 Volt batteries should be 1,52V - 1,54V and the 3Volt batteries shold be 3,1V - 3,3V in charge.
2)Take the hardened steel needle or watchmakers screwdriver and clean (scrape) both contacts off any visible residue till they are shiny. aaaaaaaUce dust blower to get rid of scrape-offs.
3)Make sure the contacts are touching the corresponding battery side only and not shortcuting the battery.
Do not forget to rate please.
SOURCE: 2 Fossil Watches wont work
fossil watches are very temperamental when it comes to there insides. did you have fossil do the band or someone else? also they sometimes have corrosion from the seals not lasting.
