Hello, Linda -
The Northwest Territory trademark may be held by Sears, which means you may have purchased your chair from Sears or Kmart.
Therefore, if you are in the USA, I suggest you call Sears Customer Service and ask about any replacement parts for your chair:
888-873-3829
Mon-Fri 6:30 a.m.-10:00 p.m. CST
Sat 7:00 a.m.-9:00 p.m. CST
Sun 7:30 a.m.-9:00 p.m. CST
Note: Don't be surprised if you cannot find the chair part you need.
Best wishes.
SOURCE: Ford Focus rear screen washer pipe diconnected at
Ir should just be a rubber hose. Just slide it back onto the fitting again. If the plastic tail has broken off the nozzle you will need to get another from Ford to replace it before hooking it back up.
Testimonial: "Thanks very much, I should now be able to fix my Dad's car for him. Brilliant."
SOURCE: water hose (metal pipe has broken) at back of
yes it will not allow the water to heat the inlet manifold but it will still work when its warmed up unless your in alaska
Testimonial: "Thanks for the help.I will bypass the hose and close it off. It's the start of summer here and like you said it should work ok. "
