SOURCE: kenwood A901
Contact a locale store that selling kenwwod and ask for a splashguard, the spare part number is KW604349 it´s a 'D' shape
SOURCE: kenwood major mixer
Get in touch with the agents
Kenwood Home Appliances
1295 Clubhouse Street
Maraisburg, Gauteng
South Africa
011-474-0153
SOURCE: kenwood chef A701A mixer not working but blender
could be one of three things
1) the belt is broken to the main gearbox (fairly easy to replace if you can get one)
2) a gear has slipped or broken which means none of the front end will operate.(I have this problem and cannot get the gear body to open)
3) If the top and front worms are turning then the problem is with the planetary gear which again is fairly easy to replace
Bill N
SOURCE: Mine is a Chef Stand Mixer but really don't know model no. Where to find?
This kind of unit are lubricated with grase paste. If the unit stays
inactive for a long time, or if the motor and gears are overheating the
grease paste gets melted into thin oil, and that will cause leaks.
To lubricate the unit, you need to spread again the grease in the gearbox, using special
foodsafe grease paste.
Disassemblying the gear box is not that easy, you will need previous
experience and a gear puller to do the job properly and safely.
This appliances are also held with security screws to prevent the users
from taking apart the unit, and can only be disassembled using a Security screwdriver tip.
The grease can be purchased here, check at the bottom of the page: Kenwood chef food mixer Grease.
SOURCE: Replacement Bowl for the KSMO35 Stand Mixer
If you are still looking for the bowl for your mixer, I have both sizes.
