SOURCE: 2002 yukon xl no power check engine light
Denalis are famous for clogged fuel filters. Change the fuel filter first and see what happens, Get the code for the check engine light. It could be you have a clogged EGR ports. Remove EGR valve and clean out the ports, replace with new gasket and see what happens. Advise of results.
SOURCE: fuel reset button on 2002 yukon
The reset button for any instrument display tallies ( fuel consumption, average, trip miles, etc ) is located on the sterring wheel. It should be the button on the lower right with the down and back arrow printed on it. Once you display the item you want to reset, hold this button for a few seconds and the display should reset to 0.
Good Luck
SOURCE: replace factory radio on 2002 yukon xl
all you gotta do is carfully pry the dash panel off (prying from the far left end is easiest) completely remove panel. then there are 2 clips that hold the factory sterio in place. push on the both clips while pulling the radio out. simply disconnect the wiring harness from the back of the radio. using an adapter avaliable at your local radio shop (scosche p/n gm02, mdarb and gm1483b) wiring harness, dash install kit, and antenna adapter. then simply match the colors on the new radio's harness to the adapter harness, crimping each connection with a "but plug". then simply follow the instructions included with the dash install kit to assemble the kit.connect the antenna adapter to radio, plug in all cables. test to see if everything works properly before the final install. install sterio into dash install kit, re installing kit where origional radio was. then simply put the panel back in its place by firmly pushing on it untill it snaps into place. then enjoy your new radio!
SOURCE: 2002 Yukon Xl locks and unlocks by itself
try taking your key phob and holding the unlock and lock button at the same time see what happens.
SOURCE: Where exactly where the EBCM is located in 2002
You mean ecm b fuse, it is in the engine compartment fuse box , look on the left fender firewall , black box labeled fuses and relays... flip lid over it is labled for you to reference...hope this helps...thanks
