SOURCE: Printing Bar Code Labels from Intermec 3400
here is the specific intermec syntax (stx(esc)E1(can)(data)(cr)(data)(cr)(etb)(etx)PRINT
You have to send this sequence with no spaces (use hex equivalent or control c etc)
You can call intermec product support or call Scan Source tech support and they will hep you
Best of Luck
SOURCE: mis align printout
hi, its hard to say but.... does it feed ok or skip labels??? if it skips labels, the sensor will need replacement or adjustment, also download the latest drivers, and if your driver or software gives u the option, play around with the magnification settings, also double check length, borders etc, try making the label length setting appear longer , shorter etc. Hope this is of help to you,M,
SOURCE: Intermec PM4i I have 4x6 labels
Check your driver to make sure you have the correct resolution driver installed that matches your print head. For example, if your print head says 203 dpi on it but you install the 300 dpi driver, it can cause this problem.
SOURCE: The Thermal transfer labels are
You can adjust the darkness level +/- 10. If you adjust it all the way to 10 and it is still too light, there is a print head pressure adjustment screw to the left of the ribbon feed roller.
SOURCE: ribbon feeds out with label on the intermec
Check to make sure that the printer is set to Thermal Transfer and not Direct Thermal. If the printer is in Direct Thermal, the ribbon take-up does not turn.
If the printer is set to Thermal Transfer then I would suspect a bad Power Supply since the ribbon take-up is driven by the power supply and not off the main board.
