SOURCE: change crib into toddler bed
You may find the following link helpful. It contains video instruction on how to set up the different configurations. Hope this help and let us know if you need further help.
SOURCE: Jardine Crib 4 in 1
step 1: detach the front panel (part j) from the front posts h(1) and h(2) using allen wrench
Step 2 if mattress support (part K) is not in the lowest position, unscrew mattress support bolts (Part d) from the post and move it to the lowest position
Step 3: Using the wrench provided, attach the guard rail (part f) using 4 bolts (part a) between the left and right front posts
Step 4: tighten all screws clockwise.
good luck
SOURCE: changing from a crib to a toddler bed
1-Lower drop side to lower position. Then on the opposite side of the crib, remove stationary side. To remove stationary side, press the small tab on the end hardware(brown plastic piece that connects the rail to the frame) and then pull rail up.
2-Before reinstalling the conversion safety rail(csr), remove the mattress support bolt that is on the side the the csr opening will be(the foot of the bed). A new bolt will be used to reattach the mattress support in the next step.
3-Slide csr hardware onto the hardware on the crib ends. Insert two 1/4-20x2" bolts into each end. One bolt will replace the mattress support removed in step 2. Be sure to put the bolt back through the mattress support bracket before screwing into the end.
I have the instruction page with pictures if you would like a copy emailed.
[email protected]
SOURCE: storkcraft aspen convertible crib with drawer
I too, need to convert my crib to the toddler daybed. My daughter climbed out last night! Anyway, I was searching for my instructions and then remembered the instructions are attached to the bottom of the mattress board......hope this helps.
Jessica
SOURCE: Need instructions converting crib to toddler bed
I have all the instructions posted in an album on photobucket.com. In the site only search field (not the web search) type emilykenepp and change the search criteria from images to people. This should bring you to my profile- under my albums I have an album titled Graco Lauren Crib Assembly Instructions. Click on that and you should be good to go! Pages 10 and 11 are for the conversions. Also, for any further assistance, the customer service number for LaJobi (the people who actually manufacture the crib for Graco) is 1-888-266-2848 and for Graco it's 1-800-345-4109. Hope this helps!
