20 Most Recent Graco Trekko 3-Wheel Stroller Questions & Answers
Shaking wheel on graco trekko
I am assuming you have lubed the wheel with a silicone based spray lube.Is it wobbling with the wheel in the locked position? Th only reason a wheel can wobble is if the axle and the actual wheel have too much play. A thin shim washer may tighten the axle to wheel spacing. Most hardwar stores will have thin washers. Give it a try. Your manual made no reference to wheel maintanance so if you purchased it new I would call Graco and complain. If used, try to eliminate the problem. If you need it here is your manual.Graco Trekko Manual
1/22/2013 5:15:33 AM • Graco Trekko... • Answered on Jan 22, 2013
Graco Ashland classic crib instruction Manuel
the lengths of screws are shown.. buy new screws and barrel nut to ensure they will work. If you have hex key take it o hardware store and choose screws that fit wrench. https://www.gracobaby.com/replacementparts https://www.manualslib.com/manual/557914/Graco-3281642-043-Ashleigh-Classic-Crib.html
2/15/2022 6:29:02 PM • Graco Baby Gear • Answered on Feb 15, 2022
Where is the motor located on a graco Duoglider swing model 2000709?
Probably better to ask them direct especially if it needs warranty repair. We are not they, we are Fixya. We just have a Graco category for handy filing of questions. https://www.gracobaby.com/home-and-gear/swings-and-jumpers/swings/ ..
9/16/2021 8:43:34 PM • Graco Baby Gear • Answered on Sep 16, 2021
Crib hardware replacement for Graco Freeport Convertible Crib
Crib hardware presents a safety issue. Best to go with what Graco supplies/recommends.
11/20/2020 2:35:42 AM • Graco Baby Gear • Answered on Nov 20, 2020
2answers
Can the Graco Symbio brake be repaired?
same problem, can't open the black cylinder, affraid to crack it. did you find the solution ?
6/2/2020 7:14:25 PM • Graco Baby Gear • Answered on Jun 02, 2020
How do you remove canopy from graco sweetpeace
You need to remove the center of the part that connects to the chair. Use a thin screwdriver into the center and then pry each of the two tabs outward from the center. As you unhook it, you will be able to pry it out and then the attachment mechanism will pull off
5/31/2020 5:50:06 PM • Graco Baby Gear • Answered on May 31, 2020
How to remove seat wire, after putting it in wrong on the Graco uno2duo stroller?
This question was posted a long time ago, but no one answered it correctly. If you put the wire in backward, look on the end of where the wire was inserted. You made have to move the fabric to see it. There are holes. Use something to push in the metal piece that is showing as you pull out each side of the wire. I used a house key to push in the button while I removed the wire.
4/3/2020 10:00:47 PM • Graco Baby Gear • Answered on Apr 03, 2020
Graco Colby pack 'n play instructions for canopy
http://s7d2.scene7.com/is/content/Newellsync/279735 Call toll free 800 number for assistance shown in online manual. (I am not posting the phone number here because of spammers posting fraudulent phone numbers on FIXYA, but manual appears legitimate.)
11/4/2019 6:49:28 AM • Graco Baby Gear • Answered on Nov 04, 2019
Instructions for Graco pak n play model number 1755168
Free online manual - possibly the same or similar model: http://download.gracobaby.com/productinstructionmanuals/ISPP071AA.pdf
6/3/2019 12:43:25 AM • Graco Baby Gear • Answered on Jun 03, 2019
I would like the instruction manual for a Graco stroller, model 7b03cst3. Serial # 1025063041
Manual for Castelon 7b03cst3 not on their web site. I suggest you contact them by phone or using their web site. http://www.gracobaby.com/en-US/contactus
4/27/2019 6:59:33 PM • Graco Baby Gear • Answered on Apr 27, 2019
What's the number for Graco
1-800-345-4109
4/26/2019 7:11:34 AM • Graco Baby Gear • Answered on Apr 26, 2019
2answers
My graco imonitor keeps beeped at about 10 second interval. All units are plugged in including the nursery unit.
Does it have batteries mine beep when batteries are low this way if electricty goes out they still work
2/13/2019 6:35:55 PM • Graco Baby Gear • Answered on Feb 13, 2019
Graco Trekko 3-Wheel Stroller Logo
2 questions posted
Top Graco Baby Gear Experts
tina gallow
David Shaub
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
View Most Popular
Graco Baby Gear
  • Graco Baby Gear
Most Popular Question
shaking wheel graco trekko
  • Baby Gear
