Microwave Ovens Logo
S
Sheila Poole Posted on Aug 27, 2017
How do we change the language on Sanyo Micro Showerwave 900w please
Sanyo Micro showerwave 900w ,needs resetting and starting up
2 Related Answers
Anonymous
  • 8909 Answers
  • Posted on Jan 18, 2011
SOURCE: my sanyo showerwave 900w diegram
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Anonymous
  • 136 Answers
  • Posted on Jun 20, 2011
SOURCE: Can you tell me where
Because I do not know the exact Model number of your Microwave Go Here and enter your model number to get the Owners Manual.
Thumbs Up if Helpful!!!
Where can I get my door fixed
I would find someone that repairs and fixes small appliances then. I would search on Google and Yahoo small appliance repairs then.
Can my microwave oven be repaired? I have a Sanyo showerwave 900W the oven & grill works but the microwave stopped working.
microwave is not that good for your health anyway, you can repair it - unfortunately i do not think that this is cost effective, it will be cheaper buy second hand working model for $10 to $20 on gumtree, craighslist or even boot sale than repair that one.
hope this will help you - do not forget to vote...
1helpful
Sanyo EM-SL20 Super Showerwave 900W Powergrill has stopped heating
see the informaton with carefully and use the common sense:
God bless you
When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem.
Can you tell me where I can find a manual to sanyo fan assisted owen 1200 w, super showerwave 900W?
2helpful
How do i unlock the control key pad on a sanyo super showerwave
Try holding down the Stop button for approximately 5-10 seconds. This is the industry standard for locking and unlocking microwaves, although your Sanyo may vary. Please let me know if this helps!
My sanyo showerwave 900w diegram emd9550seuk no power in the display
Hope this helps.
2answers
Fuse
replace it with same current rating and voltage rating.just unscrew the case.
I have acquired a sanyo showerwave 900 volt microwave unfortunately it has no manual. Where can I buy one
Hello amnally6205,
I'd start by calling Sanyo Fisher service.
800-421-5013
Monday - Friday, 7:30AM - 5:00PM PST
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Top Sanyo Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
ADMIN Andrew
ADMIN Andrew
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
