Question about Hotpoint RVM1435 Microwave Oven
Fuse How do I change the fuse on my sanyo super showerwave.
Posted by donstanleyjr on
Anonymous
  • 88 Answers
Anonymous
    Problem Solver:
  • 14 Answers
Replace it with same current rating and voltage rating.just unscrew the case.
Posted on Mar 31, 2009
Sanyo microwave windmill super showerwave EM-3490W. TOUCHPAD NOT WORKING
The touchpad may have failed but a defective connection should be considered.
Sep 12, 2017 | Sanyo Microwave Ovens
Sanyo EM-SL20 Super Showerwave 900W Powergrill has stopped heating
see the informaton with carefully and use the common sense:
God bless you
When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem.
Sep 09, 2012 | Microwave Ovens
I need a user manual for a Sanyo super showerwave 800w microwave. Model no. EM-G204 There aren't any on manuals online. Thanks Luke.
You can just type "EM-" (without quotes) in the search box at the Sanyo (Panasonic) support site here.
Check a few of the first results to see if they're close enough to help you.
If not, contact them via that page for more help.
Aug 22, 2012 | Microwave Ovens
How do i unlock the control key pad on a sanyo super showerwave
Try holding down the Stop button for approximately 5-10 seconds. This is the industry standard for locking and unlocking microwaves, although your Sanyo may vary. Please let me know if this helps!
Mar 01, 2011 | Sanyo EM-A5200SW Microwave Oven
My sanyo showerwave 900w diegram emd9550seuk no power in the display
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Jan 18, 2011 | Microwave Ovens
Microwave Repair
there are several internal fuses protecting different circuits, as long as you get a direct replacement you will be ok
Feb 18, 2009 | Whirlpool GH4155XP Microwave Oven
REPLACING LIGHT BULB
i have a cookwork microwave the light stoped working
Sep 16, 2008 | Microwave Ovens
Microwave Repair
You will need a model # to look up parts. Go to appliancepartspros.com and you can see a diagram. Use the model # on the sticker in the microwave. There will be a fuse and most of the time they are easy to get to.
Oct 08, 2007 | Microwave Ovens
Hotpoint RVM1435 Microwave Oven Logo
491 people viewed this question
Top Hotpoint Microwave Ovens Experts
William Miller
William Miller
Sheldon Dedek
robert
Are you a Hotpoint Microwave Oven Expert? Answer questions, earn points and help others
