SOURCE: F1 Error Code on MayTag range
migs, on a Maytag the F1 indicates there is a problem with the touch-pad or control itself. Usually, it's the touch pad. Try killing the power to the range and remove the touch pad ribbon from the control board. Clean it with an eraser. Power back up and see if the error comes back. If it does, remove the ribbon cable again and power up with-out it attached. If the same error still returns, then I would suspect the control board itself. Catriver..post back.
SOURCE: F1 error on the 1 draw dishwasher
I've never found personal ranting to work myself. However F1 is meant to be a flood warning, there's a sensor in the bottom of the drawer unit that stops the dishwasher if water accumulates in the casing, not the drawers!
So the error could be caused by a leaky hose, a broken or fouled lid or a blocked drain hose stopping the drawer from pumping out, at least these are the problems I've heard of or had.
TURN THE POWER OFF BEFORE TRYING THE FOLLOWING.
To see if you have water in the unit you need to remove the lower drawer, to do this open the lower drawer and you'll find the drawer release clips on each side of the drawer in the corner to the front and at the bottom. When doing this always support the front of the drawer in one hand while releasing the clips with the other. To release the clip push it in and slide it back 3-4cm while gently lifting the front of the drawer (don't try to lift it out, you only want to make the clip slide back easier!). Repeat this with each clip.
The drawer is on telescopic side rails, so while supporting the front you need to slide each side back, the clips you released are at the end of each rail and you can slide these easily by feeling just under the edge of the drawer. When they're both slid to the back you should find that the drawer will slide further forward and you can lift it out but don't try and pull it right out because all the hoses and wires are connected, just have a towel or something that you can put on the floor to protect the drawer and leave it there.
You should now be able to see into the base of the unit and see if there's water there. The sensor is attached to the bottom panel in the casing, if there's water puddled here you may have a hose or lid leak, you'll need to dry the casing out (thorougly, probably with a hair dryer before you can clear the F1 error).
On older models the lid motors on either side of the unit (they were white) did have a reputation for breaking, if you see water splashed around the sides it might be one of these that's gone, check for tell-tale signs for leaky hoses too (that would be water where it's not meant to be).
To replace motors and hoses is up to you.
SOURCE: Whirlpool Oven Model RF365PXGN getting a error of F1 and E2
HELLO, I HAD THE SAME PROBLEM. ALL YOU HAVE TO DO IS FIND YOUR CIRCUIT BREAKER BOX AND LOOK IN IT FOR THE BUTTON THAT SAYS KITCHEN. TURN THE KITCHEN POWER OFF FOR 30 MINUTES THEN TURN IT BACK ON. ONCE YOU TURN IT BACK ON THE OVEN SHOULD RESET ITS SELF. TRY THAT AND IT SHOULD HELP.
SOURCE: whirlpool washer model WTW6200SW1 getting an F1
Hi
Thanks for using FixYa. Error F1 means primary control failure and to resolve this you’ll have to replace the machine control assembly. This error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
SOURCE: Getting error code F1 and don't know what it
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
