SOURCE: drive pulley won't come off engine shaft
put the nut back on were it is even with the stud and hit with a hammer while pulling on the pulley
SOURCE: Remove the Center Support Drive Shaft Bearings
use a cutting wheel and cut through the bearing as far as you can without damaging the drive shaft.Then get a big hammer and a chisel drive the chisel into the cut and break the bearing.
SOURCE: What's the best way to remove a 240 drive shaft support bearing?
this is a pressed unit. honestly youre better off either purchasing the whole drive line or go buy the bearing new and take it to a transmission or drive line shop. they wont charge that much to remove and replace the bearing and all youll have to do is r and r.
Testimonial: "Thanks for the really fast reply. I did find a DIY method posted online, but it's very time & labor intensive. Your sound advice is much appreciated!"
SOURCE: 1986 chevy s10 trying to remove center bearing on
theres a collar on the youk.remove it and tap it out its splits the tow pieces of drive shaft.use alot of pb blaster and make sure you grease the youk theres a grease fitting there
SOURCE: New holland haybine 469 replacing bottom bearing
I'm
sorry but I believe you have this posted in the wrong product
category? Please re-post the question in the proper category if this
is the case, otherwise you have my apologies. This is the car and
truck problem category
