The Taylor 152 is at the low end of output when it comes to commercial soft serve equipment. It is rated for 102 3.5oz. servings per hour, but only 4 3.5oz rapid servings before it needs time to recover.
Possible remedies:
When you need to serve several cones in a row, you can pull the feed tube in the top. That will help the product fill the cylinder a little faster.
You could always consider a used Taylor machine that has the ability to keep up with your demand. Soft Serve Parts Taylor Machines
SOURCE: how do you make ice cream with the k-tel Quick Chill ice cream maker
K-tel International is in Winnipeg, Manitoba, Canada. I also just got the same machine with no manual. I phoned them and they are sending me one in the mail. Just go to their website; go to "contact us" and phone or email them. They were very helpful.
SOURCE: Taylor Y754-27 Soft Serve Ice cream machine
gearbox is sealed, I've never replaced one.check belts could be too tight, does it scream when you start it. check bearing at end of barrel sharp edge means needs replacing. check temperature of product disspensed on loud side could be too cold. adjust on board or needs new probe, inexpensive but a ***** to install.
SOURCE: I have a Taylor PH71-58 ice cream machine could
access code is 8333
Testimonial: "Thank you for the access code to my ice cream machine, this will help me a great deal."
SOURCE: taylor soft serve ice cream machine model #y754-27
If you need parts go to softserveparts.com tell them shaun sent you.
