Computers & Internet Logo
Lori Contad Posted on Mar 24, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I set up echo but Alexa app keeps going back to startup re downloaded still does
Vladimir Frolov
Level 3:
  • Echo Master 2,075 Answers
  • Posted on Mar 26, 2017
Vladimir Frolov
Echo Master
Level 3:
Answers
2075
Questions
Helped
415583
Points
6445
Remove it from start-up programs
2answers
What are the process to solve the Alexa Echo Setup problem?
Before Set Up Alexa Echo, you will need to download the Alexa App in your smartphone.
After Download the Alexa App, Then you will plug in the device in power outlet.
Now open the Alexa App and choose the select the Add device.
Select now! the Amazon Echo device and add it.
You can select the Echo, Echo dot or other Echo plus, Echo Show and more option
And you will complete the process How to Setup Amazon Echo device.
How do l set up my new echo with alexa
Follow link it will give you idea for same
How to set up an Amazon Echo Got a new Amazon Echo? Here's how to set it up start asking Alexa to tell you jokes. STEP 1: DOWNLOAD THE ALEXA APP The free Alexa app is a must-have if you're the owner of an Amazon Echo. You'll need it to get your Echo device set up. Download it on any smartphone or tablet with iOS 9.0 or higher, Android 5.0 or higher, or Fire OS 3.0 or higher. Simply open up the app store that comes with your device and search "Alexa app." Downloading the app on a computer? Make sure you're connected to Wi-Fi, then visit the Amazon Alexa websiteto download it.
STEP 2: PLUG IN THE ECHO This is probably the easiest step in the whole set-up process, as the Echo doesn't require any batteries in order to function. Simply plug the included power adapter directly into the Echo, then hook it up to a power outlet. When the light ring turns blue, that means the power is connected. Then, wait for it to turn orange, as this is a sign that Alexa is preparing to greet you. When that is done, you'll hear Alexa's voice telling you the device is ready for set-up.
STEP 3: CONNECT THE ECHO TO WI-FI VIA THE APP Next, you'll need to connect your Echo device to your home Wi-Fi network. The latest versions of the Echo should guide you through this process. However, if you get stuck, simply open up the Alexa app and search through the available networks until you find yours. If you have multiple Echo devices, make sure you go to Alexa Devices in the menu and choose the right device. Under the Wireless heading, you should be able to see the state of the Wi-Fi network connection.
Once you're connected, you have the option of saving your Wi-Fi password to Amazon, which makes it easy to connect to smart home devices or set up a new Alexa device on the same network - should you decide to purchase more Echoes for other rooms. You also have the choice of connecting your Echo to a public network, although the password won't be saved on Amazon.
STEP 4: START TALKING TO ALEXA To get started, say the wake word, which by default is "Alexa." But maybe there's already a human Alexa in the house and you want to change the wake word to something else? Simply tell the Echo, "Alexa, change the wake word." You can also change the wake word manually by opening up the Alexa app, tapping help and feedback, and selecting change the wake word. Currently, you can change the Echo to respond to "Echo," "Amazon," and "Computer." No word on when Amazon will allow you to customize Alexa so you can call her "Mr. T," "Honey Bunny," or "Jelly McJerkface."
STEP 5: START USING YOUR ECHO Congratulations, your Amazon Echo is all set up and ready to be used in your day-to-day life. To make sure everything's working properly, you can conduct a simple test by trying out a few basic commands. For example, say the wake word and "Hello." If your Echo is properly set up, Alexa should respond with a simple "Hello" in return.
But the Echo can do much more than greet you. In the Alexa app menu, you will see two sections called Skills & Games and Things to Try. These are both excellent ways to see what Alexa is capable of. Skills in particular can help you customize Alexa by giving her certain abilities-think of them as mini-apps from many different creators that you can use for entertainment, organization, news, and much more.
You can start using your Echo device to make to-do lists, find out the weather, check on traffic conditions, call your friends, send text messages to your family, stream podcasts, or connect smart home devices. Alexa has thousands of essential and not-so-essential skills you can add, too. Check out some of the most useful things that the Amazon Echo can help you do.
OPTIONAL STEP 6: CONNECT SMART HOME DEVICES OR AN EXTERNAL SPEAKER Head to your Alexa app menu, and select Smart Home (Alexa may show you an ad at this point, which you can exit out of). In this mode, Alexa will try to find any nearby and connected smart devices so you can pair them up. You can also choose to Add Device if Alexa is having trouble locating the device you have in mind. You can also organize devices into Groups here, and create more complex Scenes where multiple devices interact at once. Check out our post on Routines for more information.
The Amazon Echo can play also play music, and the sound quality has only improved with the second generation model. To ensure you're getting a top-notch listening experience when you jam out to music or listen to audiobooks, you have the option of hooking up an external speaker to your Echo device. For best results, get a Bluetooth speaker that's certified to be compatible with Echo devices. Keep in mind that your Echo can only connect to one Bluetooth device at a time, so if there's already unit already connected to your Echo, you'll need to un-sync them before you can connect your external speaker.
7answers
Setting up echo dot
hi roger.
see if this helps you out.
  1. Turn on Echo Dot. Place your Echo Dot in a central location (at least eight inches from any walls and windows). ...
  2. Connect Echo Dot to a Wi-Fi network. In the Alexa app, follow the instructions to connect Echo Dot to a Wi-Fi network. ...
  3. Talk to Alexa. ...
  4. Optional: Connect Echo Dot to an External Speaker.
Amazon.com Help: Set Up Your Echo Dot
https://www.amazon.com/gp/help/customer/display.html?nodeId=201994280
or if you need more help go to this link.
Setting up echo dot Google Search
1helpful
5answers
How do i setup my amazon alaxa echo dot
There are Many People in the 21st Century are Wanting Some Difference Things Who Change their Life. The Amazon Echo Dot is one of those things Who Change the Human Life through the Voice Search. It is the Product of Amazon that is Coming in the Market to Make the Human Life Perfect. Amazon Echo Dot is a Speaker that is Used in Amazon Alexa. After Purchasing the Echo Dot, Many Peoples are Doesn't Know to Setup Amazon Alexa so For It You Have to Visit Our Official Website.
Top Echo Computers & Internet Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
Thomas Perkins
Thomas Perkins
Are you an Echo Computer and Internet Expert? Answer questions, earn points and help others
