Cars & Trucks Logo
L
Lori jensen Posted on Mar 11, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 2005 dodge ram 1500 wont start and the etc light and the check engine light both stay on
Battery is good, alternator is good, and just replaced starter ran good for few days now wont start wont even turn over even with a jump
Bill George
Level 3:
  • Dodge Master 2,517 Answers
  • Posted on Mar 11, 2017
Bill George
Dodge Master
Level 3:
Answers
2517
Questions
Helped
544944
Points
7493
Check all the electrical connections . grounds and to starter. One of them are bad or the new starter crapped out on you. Remember just because it is new doesn't mean it is good. I have got new items that were junk out of the box.
2answers
1997 dodge ram 1500 4x4 abs light on runs fine idles good but put it into gear wont go past 35 mph engine running smooth even at 35 mph
Bernard's Blog: Dodge Transmission Output Speed Sensor
bernardsblog.blogspot.com/.../dodge-transmission-output-speed-sensor.h...
Sep 8, 2009 - My 99 Dodge 2500 Ram won't accelerate..transmission is NOT slipping,.... It has been running fine and the check engine light even cleared itself yesterday.... So it wouldn't go into first gear and then 3 minutes later my check engine ... I have a1997 Dodge Ram 1500 with a 5.9L instead of the stock 5.2L. It ...
Dodge Ram Idle and Stalling Problems - Car Forums at Edmunds.com
forums.edmunds.com > Dodge > Dodge Ram Pickup 1500
Aug 17, 2011 - 30 posts - ‎25 authors
Learn more about Dodge Ram Pickup 1500 at the Edmunds.com ... The crank sensorwas put on however it started stalling again. ... The truck starts fine, but will only runat 2000's RPM and only then if .... Then as I start driving about 1/3 of a mile go dead again, I knockout of gear, crank back up immediately.
WILL NOT GO OVER 30MPH WITH PEDLE TO METAL ...
repairpal.com > Questions > Dodge > Charger > 2006 Dodge Charger
I WAS DRIVING FINE AND THE CAR ACTED LIKE IT GOT STUCK IN ... Then the transmission didn't want to change into 2nd gear. .... Whenever i start up my car theabs and esp light turn on and when i try driving it doesnt go over 30 mph even .... in neutral but not it just wont go up hills and i think it has something to do with
Dodge 1500 generator light came on. Truck died, checked battery & alternator both are good.
When you say the alternator is good, what do you mean ?
If the alternator is charging the battery, the warning light should not be on.
The voltage regulator for the alternator is inside the engine computer. So the computer could be faulty.
2000 dodge ram 1500 clicking and wont start batery is good, starter is good, lights are on dash as normal, still wont start, keeps on clicking
get a jump, take it to Auto Zone or other parts store, have them run a free diagnostic on the battery, and the alternator. My bet is that it's one of the two that needs replacement.
2004 dodge ram 1500 5.7 hemi,alternator dosent charge all time , an gas light stays on an gas gauge stays on E all time
From off position turn ur key on then off three times ur problem codes will flash on ur odometer this atleast a place to starat
1helpful
My 1999 Dodge Ram 1500 wont stay started. After I got a jump, because the engine won't even turn over, it completely quits? Is it that I need a need battery?
if the vehicle will start with a jump and not continue to run the most likely problem is the alternator. the alternator supplys the voltage to all the computer functions once the vehicle is started. you may still need a battery just depends on the status of the battery. i hope this helps
New battery but still acts dead - Does computer need to be reset?
do not suspect computer.
1 the new battery may not have been charged from the store so would need to be charged before use, charge new battery on a charging set and see if this resoves the problem. *or use slave leads and start from a second vehicle)
2 your alternator may not be charging the battery so after a while it will just die. use a volt meter and check that volage is increaseing to your battery when the engine is running.
if not suspect alterantor defective and may need replacement.
05 Dodge Ram will not start or turn over even when being jumped off. Just clicks. Last night when I tried to start it, ALL THE INTERIOR LIGHTS STARTED FLASHING AS WELL AS THE INSTRUMENT PANEL.
SOUND LIKE BATTERY IS DEAD.CHECK BATTERY VOLTAGE.A GOOD BATTERY VOLTAGE IS 12.5 VOLTS.IF LOWER REPLACE BATTERY.IF BATTERY IS GOOD CHECK BATTERY CABLES FOR TIGHTNESS AND CORROSSION.IF CABLES CHECK OUT GOOD.I AM LOOKING AT STARTER SOLENOID.REMOVE HAVE IT CHECKED.REMIND YOU TURN OFF RADIO BEFORE REMOVING CABLES SO YOU WONT LOSE CODE TO PLAY RADIO.IF IT TURN OUT THE BATTERY IS BAD. HAVE ALTERNATOR OUT PUT CHECK TO MAKE SURE ITS CHARGING THE BATTERY.
2005 dodge ram wont start
Several Things
Check For Loose Ground Cable (other end not battery end.
There Is Also A Junction Involved (ground) Where Engine And Body Grounds Come Together--LOOK AT THAT FIRST.
2005 ram 1500 truck to replace a fuse for the
I drove the truck to my parent, then i try to start the truck and it won"t start/ Then said its the battery, but then i said let check the alternator. So I put my dads new battery from his jeep to my truck, then the truck started , I pulled out the battery cable then the truck stop. If the alternator was good the truck would still be on right!! Then I take the alternator to pepboy and say it pass the test , that it was good by the test machine, and to check the battery and the fuse that is for the alternator, I try to check it the fuse with a meter and seen okay but couldn't fin the one for the alternator on the truck. I hardly the drive the truck has 32000 mile the truck is a 2005 dodge ram 1500. I think is the alternator cause its making a wierd noise when accellerating. Just burn out and can't think straight.
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
