Microwave Ovens Logo
s
shirley Miller Posted on Oct 20, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I bought a Danby Microwave 2 year ago and how it is RUSTING or burnt as Plastic is crack and flaky around top inside edges. How dangerous is this to your health.
Is this dangerous to health???
J.D. Browning
Level 3:
  • Danby Master 2,760 Answers
  • Posted on Oct 20, 2016
J.D. Browning
Danby Master
Level 3:
Answers
2760
Questions
0
Helped
1015260
Points
6696
Well im not a doctor , but I do know about metals a lot . rust is oxidized steel , that at least a good part of it is the mineral iron, now ive heard that your blood needs iron daily to keep healthy , its just I do not believe that the rust enhances the taste of your food
Why is it rusting inside?
Check with the manufacturer of unit directly to see what they can or will do for you. If cosmetics are not covered under the warranty you may be out of luck. But as you say it is less than a year old and have your receipt handy .................
Performance is not affected. Relax.
We have the same F3 problem with our rangetop microwave. ..GE JVM 1650. We have a replacement keypad that a repairman ordered 2 years ago but did not need. How do you remove the old keypad and install...
Hi, I have a jvm1631 modle that looks like yours,on mine you need to remove the grill on top and then you should have a screw above clock,remove screw and lift up and the whole assemby will pop off.Then you will see tabs all around edge that you psuh in to remove plastic cover then you can unplug all wire harnesses and replace keypad. Just remember to unplug M/W first.Hope this helps.
1helpful
Randomly beeps for no reason at all. Can go 2 or 3 days then will start beeping. Day or night usually through the night.
hey i have the same problem. how log does it do it, how many beeps and how quicky. We have a danby also the 1.1 bought it about 3 years ago.
Microwave oven runs when door is open, and does not always run.
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
If you only need a switch, you can order a universal type here for $5 postpaid.
Hello. i have a sharp carousel microwave i bought one year ago and now it is making a louder noise when it's cooking plus the outside of the microwave unit is getting very hot. what do you think is the...
this is the magnetron going bad and it is heating the outside and the inside(probably not so much on the inside right?) Well this is DANGEROUS now and i would no longer use it , as it is sending waves out and thats why it is getting hot , it will need professional service as microwaves are extreemly dangerous
1helpful
Are microwave safe egg poachers doing damage to microwave?
you are not supposed to have any metal in the microwaves for cooking something , as why the other two quit , that is probably why they quit so soon
there is some more exspensive microwaves that can work even when metal is used inside( but these are special types of microwves)
My DANBY DMW744W 700 watts does not work?
What would cause the plastic turn table shaft plate holder in the center to ignite
Microwave
A microwave needs all those surfaces to be fully reflective. those scorch marks greatly affect the magnetron. it will soon burn out . reccommend a new microwave.
Top Danby Microwave Ovens Experts
ADMIN Andrew
ADMIN Andrew
vince
john h
Are you a Danby Microwave Oven Expert? Answer questions, earn points and help others
