Kitchen Ranges Logo
K
Keith Winterson Posted on Sep 02, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Have a new world 2000/3000 cooker. The timer is locked and cannot turn the oven on. Is there any way to clear the timer?
The timer has never been used. We had a power cut and when the power went back on, it was locked into the timer mode and we can't find a way to clear it. Any help would be appreciated.
Robert Rankin
Level 2:
  • Expert 378 Answers
  • Posted on Sep 02, 2016
Robert Rankin
Expert
Level 2:
Answers
378
Questions
Helped
152438
Points
803
Try turning the breaker off that it is connected to for a while and turn it back on to see if that clears the issue. When power outages happen, sometimes the power surges and sags and this can cause issues with the controller boards in appliances.
New World G60M Gas Built-In Single Oven - clock/timer is displaying a P and 00:00?
It sounds like the oven timer is set and it is waiting for you to set the start time. I tried to find a manual, I found one, but not sure if it is right. I am in Canada and this is a UK brand, so this link might work better for you.
https://www.google.com/search?q=new+world+g60m+oven+manual
https://www.manualslib.com/manual/733219/New-World-Built-In-Gas-Oven.html?page=10#manual
Dec 17, 2022 • Ovens
1helpful
Oven not working on new world 60EDOC cooker
Faulty element is likely cause or could be a dud thermostat.
Is it an expensive job to replace the oven timer on my cooker?
I can do job for a lot less money or yes you can bypass timer, No Problem. David "The Famous Forry"
Oct 19, 2017 • Ovens
1helpful
Melted knobs
New world engineer called out and fitted cooling fan there was no charge done as a gesture of good will as cooker was just out of warranty.
Oven doesnt work
you have a short most likely try to unplug for about two mins to let reset
11helpful
2answers
Electrolux EOG7330 gas cooker - electric timer fails?
Pull off bottom knob of oven shine torch down at 45degrees u will see a red plate turn off power suply and use a small screwdriver to push the plate turn power back on job done.PS Check all vents are clear to stop it over heating good luck.
Top New World Kitchen Ranges Experts
Paul Carew
john h
ADMIN Andrew
ADMIN Andrew
Are you a New World Kitchen Range Expert? Answer questions, earn points and help others
