Vizio GV42L 42 in. LCD Television Logo
Jerry Clausen Posted on Sep 01, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Vizio gv42l hard reset - Vizio GV42L 42 in. LCD Television
Level 3:
Top Expert:
  • Vizio Master 76,851 Answers
  • Posted on Sep 02, 2016
Vizio Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15007952
Points
237762
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
1helpful
How to reset tv. Have sound but black screen
LCD's use a colorful crystal see through display which only visible when light is shining through it. if you have sound and no picture it's always a faulty PSU. Very easy to change out actually.
MY VIZIO 42''COLOR IS CRAZY, IT HS BLUE OR PURPLE SHADING, I DONT KNOW WHAT IT IS. ITS ONLY ONE WEEK OLD
Reset it to factory setting,If still getting bad colors shadding.Return it,for a replacement.The backlight video board have problems.
Totally dead. Vizio GV42L
If the circuit breaker was tripped, more likely the fuse inside the TV power supply might also be blown. If that is the case there might be a short circuit in the power supply components, more likely on a diode or transistor/mosfet.
Contact these website to see if they have the parts for your plasma.
Good Luck.
May be a bad power supply, which is a common problem with these units.I have a GV42L 42" manufactured in march 2007. It works perfect except the screen has a fracture on it. The warranty is voided because we damaged the screen. I can sell this to somone who has a good screen but needs boards or speakers, etc. Or I will buy your tv that has a good screen but damaged boards in it.
[email protected]
7helpful
2answers
I need help with disassembly of Vizio GV42L LCD TV
remove all the screws and start at the bottom and push in the tabs, and work around the edges, being careful not to pry too hard, the cover has clips all around the tv. after the bottom is free and one of the corners the cover will kind of pop off if you use the palm of your hand and lightly tap as you apply sum upward pressure.
GV42L
I had this same problem. Vizio sent someone out to replace the motherboard. It didn't fix the problem. Since it was under warranty, they replaced it with a newer model VU42L. Doesn't have this problem, but it has others.
1helpful
2answers
I have a Vizio GV42L LCD HDTV. The remote no longer is able to work the TV until it is moved closer tothe unit. I have tried another remote from my cable compnay that could work the TV but I get the ame...
On the front bottom of the TV there is a little round eye. If that eye gets blocked, it'll reduce the range of the remote. Make sure there's nothing in front of it. Other than that, the sensor behind the eye could be bad.
Hope that helps...
Geno
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
