SOURCE: i changed my nokia 1200 security code (12345)but
Unlock Code:- 4333247620 Try to Download this software :- "MasterCode.sis"___(DCT3-4MCODE) Install it any S60 based Phone and enter the serial no of your Phone and it will give you a master code of your phone. or Go to your nearest Nokia service center they will update your phone's firmware version plus your lock code will also be reset to defaul code.... for free.....No Charges applied for doing this... Don't forget to rate my solution Plzzzzz
SOURCE: i forgot my security code
Hi, You may kindly note that the default security
code for all Nokia handsets is 12345. In the event the security code is changed
and you are unable to recall it, then the phone needs to be reset. You may
kindly note that the security code can be reset at any Nokia Care Center. Kindly be aware that there
will be a service provision fee associated with this service, as it is a
non-warranty procedure. You may
kindly note, once the phone has been reset, all data in the mobile will be
lost. I recommend you take along the
proof of purchase/receipt while visiting the Nokia Care. Good Luck. Thanks for using FixYa.
i forget my security code 4 my nokia 1280 and i want to open it back i need master code pls
You may
Good Luck.
