2)Swipe all open apps up in order to close up
3)You can touch and throw away up to three apps at once to save time
Once all aps have been closed, try deleted the app again
Depends on what kind of phone it is, if it's an IPhone double tap the home button and all your open apps appear which you can then swipe them up and off the screen, if it's an android phone hold the middle button or the button on the left (recent apps button) and you can then swipe them left or right off the screen
Try closing all apps then restarting the iPad. To do this, double-tap the home button to bring up multitasking, then swipe each app up to close it. Once all of your apps are closed, turn your iPad off then back on again. This will fix the crashing problem.
Hmm, best thing I can say is double tap the home button to bring up the open apps on your iPad. Then close the instance of the app (and any other apps) by swiping the screen images upwards. That should force the app to 'reboot' and may fix your problem.
Hi Anonymous, just press the home button or if you enable the assistive touch you can tap it and then tap home.
and to totally close the apps open, double tap the home key then tap the apps below which will be appearing after you double tap the home key then tap the "x" or just swipe up.
Swipe from right to left.
If that doesn't work, close Safari and reboot your iPad.
Double tap tap the home button and then swipe up on the Safari preview screen that you see right above the Safari icon. Swiping up on that screen will close the app.
Hold down on the sleep and home buttons at the same time until the Apple Logo appears on the screen. After the iPad starts up, try again.
If you are just trying to close it and have ios 7 double tap the home button and swipe up on the app. If you want to delete it, hold the app until it starts to shake. At that time you should see a red "x" on the app, tapping that deletes it from your ipad.
Double tap the home button on your iPad and try closing the app from the row of apps that will appear at the bottom of the screen. Just press and hold the icon until the red x appears, then you will be able to close the app. Once you have closed it, try restarting the app.
If this does not solve the issue, then I would recommend removing the app from your iPad completely and reinstalling the Zynga Poker App.
Double tap your home button (middle bottom). When you see your open apps press and hold on the overdrive app until it wiggles. Tap the red X to close it. Then, tap on the overdrive app icon again to reopen the app. You'll be at your bookshelf but, tapping on the book you were reading will return you to that page.
