My wild guess 1
is wrong REGION disk
Dell inspiron 15 5000
a brand new 2016 PC it seems to me,
no OS told (windows 10 was new.)
no disk title told , 1 disk or 100+ like here.
no disk region told. 1,2,3,4?
not your country told and that tells me your region code. for PC.
I'm region 1, and only buy them, here, in a brick store .
most dells can be forced to wrong regions say 6 times, the locks in.
but not external drives, what you see is what you got.
last
run VLC player free from France,
never post about DVD unless first say I live in xyz country or say I live i region 1, and buy disks from EU R2 and they fail, so that be normal.
does the external drive play music disks celled CD_DA music
if yes the driver and driver works.
leaving only region wrong or VLC missing
google VLC player and get it. for free.
SOURCE: How do I add a dell external monitor to a dell inspiron 9400
Simply use the external video port. It may require an adapter depending on the monitor you plan to use.
SOURCE: Dell Inspiron 1501 laptop screen will not work.
If you hear the hard drive spinning and you think Windows is working but you can't see an image then :-
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
SOURCE: Monitor not working on Dell Inspiron laptop. Inspiron 1501 laptop
just follow the given link ur problem will bw solved
http://www.experts-exchange.com/Hardware/Q_21896519.html
