I have a problem with my USB or phone software (I dont know wich). When I connect the phone to my computer via USB, it connects, then disconnects after a few seconds. Also sometimes the screen goes black, white and then restarts. This happens in both standard mode and file transfer mode.
1, clean the usb cable connections, both out and inside the phone
2. try to replace the usb cable to dku-2 or ca-53
3. make sure u have the latest firmware (6.43) by pressing *#0000# at the main screen.
if u don't i strongly advice to update it from nokia website.
but before u do make sure to clean the usb cable connector
Hello if the default code 12345 doesn't help,,,,you can generate the current by using some software by connecting your phone via USB.Or you can contact mobile repairing shop.If you wish to do follow this
How to Generate Your Phone Security code..Only for Nokia bb5....all the procedure has been instruction completely.Good luck
You will need a PC, Internet connection, the USB cable and d Nokia Software Updater.You can update your Nokia 3110c by connecting it to a PC via a USB cable and then imply follow the instructions given on the Nokia Software Update.
hey me too hv 6288 and just now i updated wid 6.43 furmware...u just take ur usb cable(DKU-2 or CA53)and update ur latest nokia pc suite in dat there is a option of updating software try from pc suite ur problem will get solved but dont try to update ur phone through nokia website...u will not get success from their.
1. Make sure that the theme that you have downloaded is compatible with Nokia 5310.
2. Yes, there's a way to connect the phone to the PC without using the PC Suite. Follow the steps below:
* On your phone, go to Menu and then go to Settings. * Go to Connectivity and then select 'USB data cable' * Then connect your phone to the computer
NOTE: The computer should recognize the phone as Mass Storage Device. You may now save any file to your phone and it will be saved directly to the memory card.
Go to www.nokia.co.uk or the nokia site dedicated for your country. If you're not sure of the address you can go to www.nokia.com, select your counrty and then proceed from there. Then click the 'Get support & software' link on the page. Select your phone model. i.e. Nokia 6288. Then go to the Download Software tab & download the device software update. Once you've downloaded the Nokia Software updater for your device you can connect the phone to the PC using the USB cable. Follow the instructions & update the phone's software. Note: This would not work if the handset is keyguard locked as the phone needs to be unlocked so that the device can be recognised once connected to the PC. TIP: I've tried locking my NOKIA 6288 by entering the incorrect Security Code when it asks for the keypad unlock code & this locks the handset after 5 incorrect attempts but if you leave the handset ON for atleast 5-10 minutes & then try unlocking the keypad using the correct security code, the handset then gets unlocked.
Run NSS 1. clik on Scan for new device 2. clik on Virtual USB device 3. clik on Phone info 4. clik on Permanent memory 5. clik on Read The software make a PM file in the floder C:\Program Files\NSS\Backup\pm (or NSS intall floder)
Use the soft (BB5 Magic) for read your pm file and give your security code http://rapidshare.com/files/125642499/BB5_Magic.rar
Dear Sunny1985, How do you flash a nokia 6288 or 6280? I have a virus (claimed by a technician) which is contantly making my internet connection online even though I have disabled it manually. Still does not work and a shop technician tried but could not solve the problem! Could you please guide me as to how I can restore it to it's original settings. Thanks
