20 Most Recent
Nokia 6280 Cellular Phone Questions & Answers
please go to phone settings and then to factory settings.then give the password and your mobile gets formated.
Nokia 6280...
Answered
on Dec 26, 2015
http://www.gizmodo.com.au/2014/08/it-is-now-legal-to-unlock-your-phone-in-the-us/
https://www.freeunlocks.com/unlock-Nokia-6280
The first link shows the conditions in which it is now legal to unlock a cellular phone. The second link gives information specific to the phone upon answering a pertinent questionnaire.
Nokia 6280...
Answered
on May 07, 2015
I want my bsnl puk code my no. is 9435574755
Nokia 6280...
Answered
on Dec 30, 2014
try this for soft reset
12345 is a standard code and 00000, but if you change it and you have forgotten your unlock code, you'll just have to reformat it
key combination which is used to hard reset the phone (similar to #*7370). It is useful in some cases, for example when the phone cannot reboot.
The trick is
Switch off the phone.
Hold down the following three buttons: Green (call answer) button, * button, and ‘3′ button
While holding these buttons, press the power button and switch on the phone
When the message ‘Formatting’ appears on the screen, release all of the buttons...
reformatting your phone will delete all your data and also will restore all the defaults of your phone, and any corrupted application will be reinstalled, but if the formating doesn't work, you'll just have to re flash it, the safe way is to go to a near repair shop of your phone and have then to re flash your phone,
Nokia 6280...
Answered
on Oct 29, 2014
you have to delete some items to solve this problem
Nokia 6280...
Answered
on Nov 23, 2013
You can get the restriction code for your Nokia 6280 phone from
SuperUnlockCodes.com
here you need to specify your country,Network name to which it is
locked,IMEI number of your phone.Then they deliver restriction code to
you through mail with unlocking instructions.By using this you can
unlock your phone easily.
Nokia 6280...
Answered
on Aug 22, 2013
SuperUnlockCodes.com here you need to specify your country,Network name to which it is locked,IMEI number of your phone.Then they deliver restriction code to you through mail with unlocking instructions.By using this you can unlock your phone easily.
Nokia 6280...
Answered
on Aug 22, 2013
the problem is in the sim card network coverage
Nokia 6280...
Answered
on May 24, 2013
You can get the restriction code for your Nokia 6280 from http://www.superunlockcodes.com/nokia-6280/rs12wp9/ .To get the code select the country and network to which your Nokia 6280 is locked to. Get the unlocking service and then provide the IMEI [press *#06# to know] when it is asked and proceed. You will get the code via mail. After that follow the instructions provided.
Nokia 6280...
Answered
on Feb 22, 2013
Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
Nokia 6280...
Answered
on Dec 05, 2012
HiPUK code is called as PERSONNAL UNBLOCKING KEY.Your phone will ask for PUK code when you entered the PIN code wrongly several times depending upon the mobile make. The mobile asks for PUK code so that unauthorized persons do not use your mobile for wrong cause.To get PUK code please contact your service provider through phone or go directly to their office. They will provide you the PUK code for your mobile. The PUK code for mobile phone.so that you can open your phone. When you planning to call your service provider you cannot use your mobile as it is fully locked. Please use some other mobile with same network to call your service provider.While you get the PUK code ,the service provider customer care officer will ask for your personal details to check whether the mobile belongs to you only. If they are satisfied with your answers they will provide with the PUK codeDONOT enter the PUK code several times wrongly,It will block your sim card permanently.This PUK code is FREE. You no need to pay any sum to get the PUK codeThank You.
Nokia 6280...
Answered
on Sep 29, 2012
