Samsung Galaxy S Duos S7562 White Dual SIM Unlocked Logo
A
Anonymous Posted on Mar 31, 2016
Badge provider accidentally uninstalled, how can l get it back ?
2answers
I need owner's manual
If you need ower's manual for an unspecifieed phone, please tell make and model.
You can do a google search yourself with terms manual, make and model.
Superstar Expert Achievement Badge Fixya
need owner manual
All Star Expert Achievement Badge Fixya
2answers
How do i reset my asus transformer tablet tf101 i have a blank screen will not turn on
Perform a soft or hard reset on your Asus Eee Pad Transformer Android tablet if it is not functioning correctly. Here's how.
Soft Reset
You would want to soft reset the device in the event that it has become frozen or unresponsive. To do so, press and hold the Power button on the top-left side of the device for about 10 seconds until the device powers off.
Hard Reset
A hard reset (also known as a factory reset) will clear all data and settings from the memory of the device and set it back to factory default settings. You can perform hard reset on the Asus Eee Pad using the Android OS menus or the hardware buttons.
Method 1 1. Power the Eee Pad off.
2. Press and hold the Volume Down button on the left side of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
The Asus Eee Pad will complete the hard reset process and reboot into a factory default state.
Method 2 1. Open the Settings app.
2. Select Privacy.
3. Choose Factory data reset.
4. Select Erase tablet.
5. Select Erase everything.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
How do i remove the bonnet badge on a 2001 s type jaguar
hi .. if you mean bonnet badge and not grill badge .. I'm more than 90% certain it is fixed with a self adhesive pad on the back of the badge as I've never seen holes in the bonnet for the badge, have a careful look around the edge of the badge for signs of the adhesive pad.
I accidentally uninstalled Dolby Digital audio on my Acer laptop How can I get it back?
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
1helpful
2answers
My trunk will not open when I push the badge button!
if i'm not mistaken... i believe there is a disable switch located around the lock mechanism when you have the boot open... it might have accidentally gotten bumped
2helpful
Battery disconnected and accidentally closed trunk. cannot open now. how do we open manually?
there is a manual keyhole in the XKR badge below the right hand rear lamp cluster
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
