20 Most Recent Samsung Galaxy S Duos S7562 White Dual SIM Unlocked Questions & Answers
Go to settings, select more under data usagethen select mobile network then select access point names and press menu. after that select new APN, type your network name at the name column and type internet at the APN column..u r done..enjoy ur internet
Samsung Galaxy S... • Answered on Sep 09, 2019
PUK code is related to the SIM card, not your mobile phone, and it is mostly written on the SIM Jacket, try finding your SIM Jacket or contact your Mobile SIM provider to get PUK code for your phone. P.S you can contact your SIM provider via another phone or you can visit their office in your local.
Samsung Galaxy S... • Answered on Mar 07, 2019
Has your phone been unlocked? if not try unlocking it
Samsung Galaxy S... • Answered on Dec 07, 2017
Gonto settings then spund notifications. Notifications may be a separate cstegory as well
Samsung Galaxy S... • Answered on Feb 18, 2015
change battery
Samsung Galaxy S... • Answered on Dec 22, 2014
Go to Settings>look for accounts>under accounts you will find google/whats app/skype etc>click google n scroll down...you will find remove account. click it Your gmail account is deleted from the phone...hope it was useful
Samsung Galaxy S... • Answered on Nov 05, 2014
are you kidding? please respect developers rights and naming conventions
Samsung Galaxy S... • Answered on Aug 14, 2014
Check the sim card with your friend's phone that it is working. Is your phone unlocked?
Samsung Galaxy S... • Answered on Jul 04, 2014
Let's start with the most common Hard Reset methods and go from there: Note: the different types of methods are numbered, method 1, method 2, method 3, etc. 1. When the phone is powered off, press and hold the Volume Up and the Volume Down keys both at the same time, then press and hold the Power key until a test screen that shows some available options appears, usually takes about 15-20 seconds. When that screen pops up you can let go of the keys. Press the Volume Down key to navigate down through the options until it highlightsFACTORY RESET then press the Power key to select it. 2. Power the phone off all the way, press and hold the Volume Down key and press than release the Power key, still holding the volume down key for about 10-15 seconds. When you see some additional options pop up on the screen you can let go of the keys. Press the Volume Down key to navigate down through the options until it highlights the reset option; it usually says FACTORY RESET, then press the Power key to make the selection. 3. While powered off, press and hold the Home key, while continuing to hold the home key power the device on by pressing the Power key. Once the Android Recovery screen appears release the Home key, then while on the Android Recovery screen, press the Volume Up and Volume Down keys both at the same time. If/when you're on the Android System Recovery screen release all the keys, and then use the Volume down key to navigate down to the "wipe date/factory reset" option. Once it's highlighted press the Power key to select it. Once you see the "Confirm wipe of all user data?" Press the Volume down key to highlight "Yes-delete all user data", then press the Power key to select it. 4. Power the device off, then press and hold the Home key and press and release thePower key (while still holding the Home key). From the Android Recovery screen, press the Search key. Tap to select wipe data/factory reset then select Ok (located in the lower left of the screen). Note: if screen is not responsive use the Volume keys to scroll and theCamera key to select. Select Yes - delete all user data, and then select OK (again lower left). Select "reboot system now" and press OK. 5. This is becoming a common hard reset method and can be used to factory reset Samsung's more recent Galaxy smartphones such as the Samsung Galaxy S III, the Samsung Galaxy S4, the S5, the Samsung Galaxy Note the Note II and Note 3, etc. With the device powered off press and hold the Volume Up key the Home key and the Power key all at the same time. When the phone vibrates (or you see the GALAXY Logo) release the Power key but continue to hold the Volume Up and Home key. Continue holding the Volume up and Home key until the "Android system recovery" screen appears. Use the Volume buttons to scroll to and highlight the "wipe data/factory reset" option, and then use the Power key to make the selection. Once the factory reset is finished you may use the Volume and Power keys to highlight and select the "Reboot system now" option and the hard reset will be complete and your cell phone will be nice and squeaky clean. 6. Here is an alternate reset for a Motorola Atrix still running on the 2.2 Android OS... While the phones power is off, press and hold the Volume down button and press and release the power button (note: if it doesn't work after all the steps listed try holding down the power button along with the volume down button in this first step). A "Fastboot" screen should pop up, press the Volume down key to cycle through the choices until you get to "Android Recovery", then press the Volume up key. Wait for the "triangle!/Android". Once it pops up you'll need to tap on the bottom right corner of the screen (note: it may take a few attempts). A menu should pop up. Tap on "wipe data/factory reset", and then tap OK. Another confirmation screen will appear. Tap Yes and then OK. After the data is cleared the "reboot system now" option should appear and is highlighted by Default. Tap OK. Note: this type of reset is common on the 2.2 (Froyo) before the tech geeks wised up and removed the need to use the touch screen. 7. This reset is for the same phone, the Motorola Atrix, but one that's running on the 2.3 OS. Power off the phone, press and hold the Volume down button and Power button simultaneously while powering on the unit. The "Fastboot" screen should pop up. When it does press the Volume down key to cycle through the choices until you get to "Android Recovery", and then press theVolume up key to boot in this mode. Wait for the "triangle!/Android" screen to pop up. Once it does press both theVolume up and Volume down keys simultaneously. A Recovery Menu should pop up. Tap on the Volume down key until "wipe data/factory reset" is highlighted, and then tap the Power button. Another Confirmation screen will come up. Tap on the Volume down key until it highlights "Yes" and then tap the Power button to make the selection. After it's done make sure "reboot system now" is highlighted and then tap thePower button. In this method you don't have to use the touch screen any more. So let's say your touch screen isn't responding therefore you can't navigate the phone or go into your settings and do a regular factory data reset. Well now on the 2.3 there is hope. Just power off the phone and perform these steps and the reset should go through. 8. Here is a hard reset for a Sharp Android Smartphone. While the device is off, hold the Sym button (it's located on the keyboard) and thePower button simultaneously. Once the Android boot screen appears highlight the Wipe data/factory reset option by using the volume buttons. Then use the Return key (on the keyboard) to actually make the selection. Scroll down to Yes - delete all user data and then press the Power key to confirm. Once it is done select reboot system now and press the Power key to confirm and reboot your handset. Important Note: On some Sharp models (such as the Sharp FX Plus ADS1) if holding the Sym button and Power key simultaneously doesn't take you directly to the Android system recovery screen you might have to do one additional step. If using this hard reset key combination takes you to a screen which shows an exclamation mark within a triangle, then press the Home key (while on that exclamation mark screen) and this should take you to your Sharps Android system recovery options.
To uninstall the app, just hold down on the icon for approx. 2 seconds, and drag to the top where it says Uninstall.
Samsung Galaxy S... • Answered on May 16, 2014
Hi Navya, You may want to try this steps I have for you resolving your issue on roaming how to remove. Hope it helps. First, press and hold the Power button for 2-3 seconds. Tap Airplane Mode. Wait for 1 minute. Press and hold Power button again. Select Turn off Airplane Mode. See if your phone will be normally or still get Roaming. If not, turn off your phone. Turn it back on. Go to Settings->Wireless & Network->Mobile Networks. Tap to UNCHECK Data roaming. See if your phone will work normally. Please let me know if this answer will work out. If does not work or you have any questions/concerns, do not rate yet! Click on Reply to Expert to reply so we can continue to work on this issue. Thank you! If the icon is gone As long that you went inside the Mobile Networks settings and UNCHECK the Data Roaming box. That should work fine.
Samsung Galaxy S... • Answered on Apr 26, 2014
this is often a common fault take it back to the shop where it was purchased and I think they cover a 2 year warranty so will either repair or replace the phone for free.
Samsung Galaxy S... • Answered on Apr 15, 2014
may be the wall charger unit, or the phones internal connector is damaged
Samsung Galaxy S Duos S7562 White Dual SIM Unlocked Logo
145 questions posted
Top Samsung Cell Phones Experts
Michael Thomas
Michael Thomas
Dan Webster
Dan Webster
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
Galaxy Samsung
  • Galaxy Samsung
Most Popular Question
make internet setting in samsung galaxy
  • Cell Phones
