Gas ovens invariably have a safety thermocouple to cut the gas off automatically if the flame goes out, due to an interruption in the supply for instance. The thermocouple must be temporarily over-ridden for the purpose of lighting the burner and pilot and often the override is mechanical but considering the clock and ignition has stopped working it would be reasonable to assume your oven has an electrical or electronic thermocouple override.
It would seem either the mains supply to your cooker has failed or the internal power supply has a problem. With such a sophisticated oven, even if you had been able to light it manually, it is possible the temperature control wouldn't have worked.
SOURCE: Zannussi Gas cooker
make sure clock is set properly - refer to your instruction book. to test if clock is in fact faulty, access the clock and bypass it by shorting together the two wires to the clock relay
SOURCE: need to set clock on my cannon chichester oven
Go to www.cannonservice.co.uk/hs/pages/manual/manualSearch.do you should find your model there. Terry.
SOURCE: MY CANNON CAMBERLEY main oven is not working at all
You need to press the cook period button. You'll see a counter that says 0.00. Press the + (or - button if you have gone too far) to set the time you want the oven to stay on for. When the timer runs out, it will beep with the alarm, and at the same time cut off the gas supply to the oven.
Annoying, but a good safety feature. I normally put 3 hours on to make sure it stays on for the full length I am cooking for.
How do I get my grill working???? Its how I found your question. The dial won't even turn in that direction, and I am sure there is a similar safety device in place. Might be the same one. Will try (just typing helps me think).
SOURCE: Gas cooker, the oven works but no gas going to rings
you need to check the pipe that take gas in to rings , and check the adjuster button .... where you live may be i can help you
SOURCE: STOVES 900DFa not working
Probably a silly Q but does the clock come on?
My \\\\\\\\stoves needs the clock setting before the oven and ignition will work
