Lawnflite 46 spo mtd rotary lawn mower
SOURCE: Troy Bilt Lawn Mower pull Cord broken
there should be four bolts holding the cover on that houses the pull cord assembly take the bolts out look inside you should see the rest of the broken cord at the other end there is a spool that the cord rolls up in to pull the cord until it stops the other end of the cord is a not in the cord pull on the knot the broken peice should come out turn the spool 2 times in the direction that is against the pressre while holding the spool in place feed the new cord in through the whole that you pulled the broken cord out of then tie the cord in a knot wind the rest of the cord up then feed the other end of the cord through the new pull handle tie the cord in a knot put the housing back on
SOURCE: Cannot pull the cord more than 6 inches to start Toro lawn mower.
Hi Patti, If you can not pull the cord more that what you said, try removing the spark plug and see if that makes a difference, if not, leave the spark plug out to prevent accidental starting, raise up the front of the mower and see if you can turn the blade if not...it only gets worse from there. If you can't turn the blade from under the mower, the engine is more that likely seized up, sorry
SOURCE: what size drive belt for a mtd lawnflite 11 hp
(1991) 131-531C611/505
(1990) 130-531C611/505
(1992) 132-531C611/505
(1993) 13-505 / 133C561C611
SOURCE: Toro lawn mower won't start with electric start.
need more information. on this so i can help you.ok let me know please
SOURCE: lawn mower pull cord
This works best with two people. Remove cover and pull cord will be inside cover. If your handle on pull cord is attatched to a metal ring up on the handle, you will need 8 foot of new pull cord.
With all the old cord removed, wind cord pulley 6 revolunations, now, have someone hold the pulley, while you string the new cord thru pulley and out the cord hole on cover. Be sure to put a knot on the end going thru pulley. Draw cord all the way thru and out of the cover. Attatch the handle and let it rewind. You will have extra cord, this will be used up going from engine up the handle. I hope this helps
