Check for circuit breaker being tripped. Quite often the breaker protects both pieces of equipment. The Breaker handle will be positioned between "on" and "off". Push the handle to off, there will be resistance, but push it all the way to off, then push it to "on". You may find this also fixes the disposal problem as well.
Check the reset button...
Here is a tip that I wrote that will help you to figure out what is going on with your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed
heatman101
