Tablets & eReaders Logo
lee Jay Posted on Oct 03, 2015
What does this message mean
It was sent back to me on my Motorola phone because I was trying to get on the internet
How do I remove contacts from mess. on my iPad
Follow these detailed steps , and you can remove phone number from iMessage.
1. Remove phone number from iMessage on iPhone
Step 1: Make sure your SIM card is in your iPhone. And turn on your Iphone, then open Settings.
Step 2: Tap Messages.
Step 3: Tap "Send & Receive".
Step 4: Turn iMessage off.
Of course, if you no longer have the iPhone, or maybe you drop it to your bath tub and it's no longer functioning, this is not an option, which means you'll have to go another route.
2. Remove phone number from iMessage online with Apple's "Deregister iMessage" service
Step 1. Go to Apple's dedicated "Deregister iMessage" service. By the way, you can enter into the Apple website to seek for the "Deregister iMessage" service.
Step 2. If you no longer own the device, find the "No longer have your iPhone?" menu. Enter the phone number you'd like to de-activate from iMessage and click Send Code.
Step 2. Check your current phone for a text message and enter the code that you're sent. Wait for a bit and you should get a confirmation that your phone number has been deregistered.
For more details, check: How to Remove Phone Number from iMessage?
Trys to connect to the internet when it trys i get an error message lost connection please try again, iv tried every thing please help its new
call your cust service for your tablet or since is still under warranty, will have to be sent back for repair, but you still have to call cust. support
The connection to the server timed out keep coming up whenever i try to use the internet
"Connection timed out" can be a problem at your end, at the far end, or in between. Try going to a different page - if you were trying to get to Google, try Yahoo, Facebook, or DrudgeReport instead. If all those fail, it's probably not a problem on the far end. It might be communications, it might be your phone. You could try turning off your phone - I mean really turn it all the way off, not just turn the screen off. If it has an alarm clock function and that still works, your phone's not off. If it has any light on at all or responds to your touch in any way, it's not off. Once it's off, let it sit for 2 minutes or so and then start it up again. Watch for any error messages or alert boxes. Without more information from you, I can't really help you figure out if it's your phone or the network.
Nabi jr has a green android laying on it's back with red exclamation make, want do anything. How do I fix it?
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
6. Use the volume buttons to move up and down through selection in this menu.
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option.
9. Scroll down to select "Yes, delete all user data".
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet
Can not log in, says my password is incorrect
If you can't remember the PIN/Password then you may have to do an external data reset. Ensure you are connected to WiFi to ensure it isn't just an issue because you aren't connected to the internet before resetting. Then go to Motorola Support Find Answers Motorola Mobility Inc to locate your device and find external reset instructions.
Mark
Motorola Support
Internet stops working when I go to favorites tab
Hi Edward, notmthatbI know much about the internet, when you said the internet stopped working, do you mean only only the previously set page (bookmarked some pages before and when you try to go back and it would not show?) or the whole entire network is down? meaning can you still get on other web pages once the black out is over and you try to google something else and it let you do that.
I am trying to see if it is your internet is not stable or it is the previously set bookmarked page is no longer existed (so often a site out there requires maintenance and fee to keep up, so if a site do not get enough visitor, the owner may not continue the service and to take it off).
again, I am not an expert at all, I just happen to own SamSung tablet.
Error connecting to server
Error messages can mean several things. You may have lost internet connection for a short period or your tablet may be having problems with downloading. This is a common problem that happens to devices if they aren't working properly with internet or you could have interferance. Try down loading later at night, late late and see if it just happens to work.
How do I send IChat without getting "messages not
Hello, Peggy.
I'm working on your solution, but need more info:
1. What MAC operating system are you using ?
2. Is this an intermittent problem or consistent one ?
3. Does the problem occur when sent to all recipients or a specific one ?
4. Are you going through AOL ?
5. What make and model of your router ?
6. When did the problem begin ?
7. Experiencing problems with Internet access ?
Sorry to ask all these questions, but I'm trying to narrow your problem.
Thanks ... NinaE
Top Motorola Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Motorola Tablet and eReader Expert? Answer questions, earn points and help others
