SOURCE: I need to know the front wheel tourque for my
The front tire can be removed (motorcycle on lift) without loosening calipers or any other parts once axle shaft has been withdrawn; after the tire has been changed and the wheel and axle shaft is back in place, torque for the axle nut is 58 ft.-lbs (78 nm) and the pinch nut is 14 ft.-lbs. (19 nm). FYI - bolts for the caliper should be torqued to 30 ft.-lbs. (40 nm) as a precaution.
Contact the manufacturer of the coach for their owners manual. However, each appliance will have a separate owners manual form its perspective manufacturer, i.e., Water Heater = Suburban, A/C = Dometic, Refrigerator = Norcold, etc.. There will not be a diagram of electrical or plumbing as a majority of the RV manufacturers do not publish that information.
