Facebook is available in 70 languages.
The language settings can be easily changeda few clicks and your whole page will be displayed in the selected language.
This can make changing it back difficult at first glance.
If you've inadvertently switched languages, going back to English is easy if you know where to look.
Log in to your account and follow a few simple steps that work regardless of the language you've changed to.
Visit facebook.com on your PC language settings are not available on the mobile site.
Enter your email address and password into the fields at the top of the page, then click the "Log In" button.
Scroll to the very bottom of the page.
You will see the word "Facebook" followed by a copyright logo.
Your current language is displayed next to the copyright symbol.
Click on the language a popup window appears, displaying all the available languages.
Click "English," then select your desired version of English.
With the satnav turned off press the bottom right corner of the screen and turn it on. This brings up an option to reset it. There may be an easier solution however that will not lose you your favourites etc. I presume the problem is that it's in a different language and you want it back to English. Resetting it will not do this. To get back to English;
Press TOOLS (The spanner symbol on the bottom right corner of the screen which shows WHERE TO and VIEW MAP) This may take some trial and error if it's in a foreign language but should be possible)
Press SETTINGS (The spanner icon) or LOCALE (the blue icon) on some models that don't have a settings menu)
Press LANGUAGE (the lips icon)
This brings you to a screen with 3 items; VOICE, TEXT LANGUAGE and KEYBOARD. Press each one in turn and select English or American English if you're in the USA. With the VOICE setting you may have to select a name rather than English. If so select the name of a person from an English speaking country.
Set English language: 1. Menu 2. Down 7 times, Right soft button 3. Down 3 times, Right soft button 4. Down 1 times, Right soft button 5. Down 4 times, Right soft button 6. select language now
The simplest way is to have your dad insert a paper clip tip into the "Reset" hole in the gps case. This will set the unit back to factory defaults and it will prompt on startup to select a language.
Select your language. If you have an iPod nano or Fifth Generation iPod (iPod with video):
Scroll down to the last menu option but don't select it.
Scroll up one menu item. This should be Settings.
Press the Center (Select) button. This takes you to the Settings menu.
Scroll down to the last menu option but don't select it; in English, this is the "Reset All Settings" option.
Scroll up to the third menu item from the bottom one. This should be Language.
Press the Center button to select Language.
Select your preferred language from the list.
If you have an older iPod with color display (including iPod photo)
Scroll to the fourth menu item in the screen and press the Center (Select) button. This takes you to the Settings menu.
If your iPod has a monochrome display (black and white):
Scroll to the third menu item in the screen and press the Center (Select) button. This takes you to the Settings menu.
If the instructions above don't enable you to change the language on your iPod, try using the "Reset All Settings" option at the bottom of the Settings menu. If the Reset All Settings option does not work, you can restore your iPod back to factory condition and reselect the display language.
for more details just click the link below
http://support.apple.com/kb/HT1824
rate the solution if it helps.
thanks.
Turn the camera on and press the menu button. Press the down arrow to get to the line that says "set". Press right arrow. Press down arrow until you highlight icon of person talking. Press right arrow and pick the correct language.
