Lands Phones Logo
Mary Kay Smith Posted on Mar 24, 2015
How do I remove the red flashing light on my phone?
A
Anonymous
Probably means that you either have a missed call or message on your machine try deleting the call history and deleting all old messages. that might turn it off
How do I turn the red light off from flashing on the hand set
The red light flashing on your handset could indicate that the phone is in an alert state, or that there is an incoming call or message. To turn off the red light flashing on the handset, you can try the following steps:
  1. Check the display: Make sure that the phone is not in silent or vibrate mode, and that the ringer volume is turned up.
  2. Check for missed calls or messages: See if you have any missed calls or messages that could be causing the red light to flash.
  3. Check for other alerts: See if there are any other alerts, such as low battery or signal strength, that could be causing the red light to flash.
  4. Check for software updates: Make sure that your phone is running the latest software update. Sometimes, software updates can fix bugs that cause issues like this.
  5. Check the settings: Go to the settings of your phone and check the display settings, make sure the red light is turned off.
  6. Check with the phone's manufacturer: If the problem persists, you may want to contact the phone's manufacturer for further assistance or check if the device is still under warranty.
Jul 22, 2019 • Cell Phones
1helpful
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 • Cell Phones
I cannot find my manual for my BT Studio phone. I cannot delete my messages on it and hence it will not allow anyone to leave a message. The red light is just flashing all the time. I have unplugged it...
Hi, when a phone it is continuously flashing red light, it means that memory has been affected by VIRUS.
VIRUS can damage a phone in no time. VIRUS can be caused by downloading applications on your phone through the internet, or might be from data transfer from a phone to another phone.
To remove the VIRUS, you will need to flash the phone memory. Flashing the phone will restore back the phone to it normal state.
You can use this link to see how to flash your phone
To flash a phone you will need to rewrite the PRL file by connecting your phone to a computer with the needed equipment. Your best bet is to take your phone to a dealer that flashes phones on a regular basis. For more information
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm.
Take care.
Jan 25, 2011 • Cell Phones
12helpful
2answers
Phone doesent turn on flashing red light when you push the power button. please help.
Try this , it helped me. 1. plugin the charger (or data cable) for about 15 minutes and keep the red light blinking. 2. while the charger (or cable) is hooked to the phone, remove the battery and memory card for 10 to 12 seconds. 3. keep the memory card out and put the battery back in and whalah, it startes up. (really hope this helps)
2helpful
2answers
Blackberry Bold Won't turn on red LED light flashes
The four flashes may actually be a "2+2", indicating that there is no software installed on the device.
7helpful
When connecting up to charge red light comes on 'power on' button on front and no charging happens - any ideas? thanks
What does indicator light mean?
  • Steady red light: Battery is charging.
  • Steady green light: Battery is fully charged.
  • Flashing red light: Battery needs charging.
  • Flashing green light: The music receiver is switched on.
  • Flashing red/green light: The music receiver is available to be added to your phone.
3answers
While charging my O2 atom exec, the LED (Flash light) does not glow red ?
I have the same problem. What I did several time is to actually shut down the phone, remove the battery and leave it like that for several hours (3 to 4 hours). Then, I put the battery back in the phone, and it would charge again. However, due to the long time with no battery, the phone's clock would be reset to January 2007.
I found no other work around right now. However, I have to do this more and more often, almost once a week ...
4helpful
3answers
My phone will not show it charging and will not turn on, red light flashing
Mine started acting wierd and it was flashing on and off. someone told me to press:*and # together with the power button.
Oct 19, 2007 • Cell Phones
Top Aastra Telecom Lands Phones Experts
k24674
Are you an Aastra Telecom Lands Phone Expert? Answer questions, earn points and help others
