Question about Aastra Telecom Aastra 8314 Corded Phone
How to set date and time on aastra 5370 - Aastra Telecom Aastra 8314 Corded Phone
Posted by bhaiya26 on
Anonymous
    New Friend:
  • 66 Answers
I suggest you consult the user manual.
You can get it in PDF format here : http://www.aastra.com/cps/rde/aareddownload?file_id=7959-13627-_MAS_XML&dsproject=aastra&mtype=pdf
Please rate if this answer helped.
Thank you!
Posted on Feb 28, 2011
The red light on my Aastra phone 9133i does not blink when I have a voicemail message
Phone your provider and ask them to turn on the indicator light. If you hear beep beep beep when you have a message they have it set wrong. Tell them you have a red light on your phone. They just set it incorrectly . Happens all the time hope this helps
Oct 24, 2013 | Aastra Telecom 9116 Corded Phone
Aastra voicemail
This Depends on your providers system . If yo go and retrieve your messages and hit 4 3 2 2 this will get you to nowhere you can record a message for incoming calls. If you want to change you message for when some calls you and you are on the phone you would do the same as above but hit 4 3 2 1. That is where you change your "on the phone message" never put a date in that one. Just record " hi I am on the phone at the moment please lease a message at the tone" Hope this helps
Apr 26, 2013 | Aastra Telecom Aastra 9417CW Two-Line...
Aastra 9110 message light doesn't light
were you able to get this working? hat did you have to do?
Dec 07, 2012 | Aastra Telecom Aastra 9110 Single Line...
How do you change the time on a Meridian NT4X43 phone?
Press "Program" button
Press "Right Arrow" button until you see "Time and date set"
Press "Hold" button
Enter the current information
Press "Hold" button
Finally press "Rls" button and the correct information will show on display
Mar 15, 2010 | NorStar Aastra M522 Expansion Module,...
Do the Norstar M7208 and Aastra 9120 phones compatible on the same PBX? I have a M7208 that works fine on current PBX, but new Aastra 9120 doesn't work. Should they both operate on the same PBX?
No, the M7208 is a propriatary set which requires the PBX to function, whereas the aastra phone is a stand alone set which requires a standard telephone line and a power source.
Dec 23, 2009 | NorStar M7208 Corded Phone
Need to adjust date and time on screen.
Just above the Hold button, with the Aastra name display, that is a sliding piece that will uncover your setup menu button. Press that and navigate to time/date settings.
Hope this was helpfull.
May 04, 2009 | Aastra Telecom Aastra 9316 CW Corded Phone
Cannot get "for free service press O.K., etc." off my screen
Bell has discontinued their process to wipe out the ad. Aastra Telecom manufactures this phone and has a 9 step procedure to clear the Bell I-Select Advertisement. Herre's a copy:
WARNING: This procedure will permanently erase the Callers List and Directory in your 390 telephone. Please record important names and numbers before implementing this procedure. This procedure disables the programming of the idle screen, so it will not only get rid of the ads permenately but you will also lose the ability to program any of the softkeys on the idle screen as well.
1) Press the Options button (the short button below the orange Goodbye button)
2) Press the Down Arrow 4 times or until the cursor points to Area Code and press Show
3) Press the Down Arrow 2 times or until it points to entry 3.
4) Press Change
5) Enter 0099 and press Done 2 times to return to the Options Menu
6) Press Up Arrow 3 times or until the cursor points to Time/Date and press Show
7) Set the Date and Time to Jan 01 12:00am and press Done
8) Press Goodbye to return to idle screen and verify the Date and time are correct
Before the time changes to 12:01am perform the next step (if the time does change, return to step 7)
9) Press these keys in sequence: Option, Mute, 0 (zero)
Your telephone will reset and the Ad message will be permanently erased.
Mar 25, 2009 | Aastra Telecom Powertouch/Vista 390 Corded...
How do I erase the "I Select" features from the Vista 390 screen?
None of the phone numbers I have to delete this annoying problem work anymore. Is there another solution out there?
Feb 02, 2009 | Aastra Telecom Powertouch/Vista 390 Corded...
Aastra telecom 9316 cw
Yes:
http://www.aastratelecom.com/cps/rde/xchg/SID-3D8CCB73-12A0DEC9/03/hs.xsl/21564.htm#dl_instructions
Look at the bottom of page.
Mar 21, 2008 | Aastra Telecom Aastra 9316 CW Corded Phone
Aastra 9110 Single Line Corded
Press the setup key and use the down,up,across arrows on the upper of the set below the window to find the date and time. Let me know if you get it done.
Feb 18, 2008 | Aastra Telecom Aastra 9110 Single Line...
Open Questions:
Aastra Telecom Aastra 8314 Corded Phone Logo
1,240 people viewed this question
Top Aastra Telecom Lands Phones Experts
Marvin
Marvin
k24674
Are you an Aastra Telecom Lands Phone Expert? Answer questions, earn points and help others
