Go to your events/calendar. Click the little settings symbol there. Then uncheck 24-hour time and save.
How do I change my clock settings from military time to regular time.
just found this on the internet dont no if this will help you out if not let me no.
Casios have 2 time modes.The 12 hour mode (am,pm) and the so called "military time" 24 hour mode.When your set time,date,year there is an option 12H or 24H.Choose the 12H by pressing the lower right button when in setting procedure,I say again.Press tthe upper left "ADJUST" button to finish the procedure.
Actually all the hours are military time. They are the same for the first twelve hours of the day. If you go through the setting procedure it will ask you if you want "12" or "24" hour time. Select 12. "24" is military
After much frustration, I found the solution... Push the set button while on time mode. Push mode until the hour is flashing.Push Split/Reset. That should be your solution!
Hello I have the same watch and had the same problem. You press the mode button till you get to the point to change the main time, you then press the reset button (bottom button on right side of the watch)to toggle to the hour place, you then cycle thru the time untill the "h" in the top right hand corners disappears and then the watch will be back on regular time.
