20 Most Recent Casio G-Shock Green Resin G-8100B-3DR Questions & Answers
Casios have 2 time modes.The 12 hour mode (am,pm) and the so called "military time" 24 hour mode.When your set time,date,year there is an option 12H or 24H.Choose the 12H by pressing the lower right button when in setting procedure,I say again.Press tthe upper left "ADJUST" button to finish the procedure.
Casio G-Shock... | Answered on Feb 06, 2014
This is an old problem, but maybe this will help someone changing a battery on a Casio. Many Casio watches must be "zeroed out" by putting an pointed tweezers between the back of the battery and the AC terminal off to the side of the battery. On my old Casio Telememo 50, the AC terminal is in a very small hole just above the battery. On the Baby G force, it was in a wider opening, way at the edge of the watch. It has something to do with resetting the watches circuitry so it will operate again. Good luck!
Casio Watches | Answered on Jul 22, 2020
Springs? No springs in a solar powered electronic watch. If there is anything wrong with it, return it to Casio for repair.
https://www.google.com/search?q=Casio+WVA-430TU+Wave+Ceptor
Casio Watches | Answered on May 02, 2020
Go to the Casio website here:
http://world.casio.com/wat/download/en/manual/
Enter the 4 digit code that is on the back of your watch, and the instructions will appear.
Casio Watches | Answered on Apr 01, 2020
On the case back usually or user manual
Casio Watches | Answered on Dec 16, 2019
C`mon download manual for make and model of watch as a pdf and read
Casio Watches | Answered on Nov 02, 2019
Download the Casio watch manual pdf and read
depends on your use of watches and the environment you tend to be in. If you are somewhere that allows you to see whether there it is day or night, than using 12 hr setting will work just fine. However if you're in a place that keeps you secluded and you are not able to determine whether it is day or night than 24 hr. setting will help you keep track of not just the time, but whether it is day or night.
Casio Watches | Answered on Sep 30, 2019
Could be poor battery contact
Casio Watches | Answered on Sep 27, 2019
I have one also and number is 612574 so that must be a serial number. have no idea of value.
Casio Watches | Answered on Aug 30, 2019
To set time and date, you must in "Time Keeping Mode" (display day, date & time) then press and hold the left-up button until it start flashing. To set press right-down button, to go next setting press left-down button.
To toggle between 12-hour to 24-hour, again, must in "Time Keeping Mode" then press right-down button.
here is the manual https://support.casio.com/storage/en/manual/pdf/EN/009/qw2672.pdf
Casio Watches | Answered on Aug 19, 2019
Casio G-Shock Green Resin G-8100B-3DR Logo
1 questions posted
Top Casio Watches Experts
Janelle Schoonover
Janelle Schoonover
Bruce Robin
k24674
Are you a Casio Watch Expert? Answer questions, earn points and help others
View Most Popular
Casio Watches
  • Casio Watches
Most Popular Question
gshock g 8100 some reason time zone
  • Watches
