Ovens Logo
W
Warren Stone Posted on Jan 08, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Does anyone know where I can get a replacement timmer for Stoves oven 900ef - 059040411
The timmer on my oven has broken and I am trying to find a replacement = the manufacturer says they are now obsolete, so I am looking elsewhere to find one = if you can help out it would be much appreciated
atp1962
Level 3:
Master:
  • Master 401 Answers
  • Posted on Jan 08, 2015
atp1962
Master
Level 3:
Master:
Answers
401
Questions
0
Helped
219829
Points
1167
You can find the online at several sites, they will be universal however so you will have to know the diam. and how it connects etc, but I am sure you can find something that will work.
2answers
My oven has stopped working
notify the owner for fixing it
Stoves 900ef oven.How can I remove the door.
1. Open the oven door and remove the 2 screws at the side of the inner glass window 11cm above the hinges and lift off the door. Place it somewhere safe!
2. Remove the 4 screws that you can see nearest to the left and right edges of the oven with the door removed. These secure the oven to the kitchen unit.
3. Slide the oven forwards about 20cm out of the unit, being careful not to pull on the cable.
4. Each hinge is held in place by 2 screws at the side of the unit now exposed, about 18cm apart. Remove them and slide out the hinges. Reassembly is the reverse of the above.
5. Note that the hinges have no means of adjustment. If not working properly, renew them.
1helpful
How to remove broken-off metal part of oven bulb in Stoves 900EF oven.
SPRAY IN PRODUCT LIKE NUT BUSTER, OR PENETRATING SOLVENT WD40. WITH SMALL SCREWDRIVER GIVE A QUICK TAP WITH HAMMER. IT SHOULD LOOSEN UP JUST ENOUGH GRAB WITH A NEEDLE NOSE PLYERS AND TURN LEFTY LOOSY /RIGHTY TIGHTY. GO IN CORRECT DIRECTION!!
The hinge on the main oven door of my heritage 900ef needs replacing. Where can i buy one from please
Well, you can try STOVES and see what they will charge, and/or try espares. Once you have the part number, google that to see if anyone else can supply.
You may want to think about replacing both hinges and the springs at the same time, to ensure the door works/closes properly. Also, check the rubber seal round the door, then tend to become brittle when at the end of their service life, so it may pay to include that with the order as well.
How do you set the clock on a stoves 059040411 oven?
I don't know what model oven this relates to, STOVES may be able to help you if you need to take this further. For the 720ef , this is what you need to do.
There are five buttons on the clock panel and from left to right they are:- Minute Minder, Cook time, Ready Time, Plus and Minus.
TO SET THE TIME OF DAY
Press the Cook Time button and the Ready Time button simultaneously. Use the Plus and Minus buttons to set the time.(24hr clock).
TO SELECT AN ALARM TONE.
Press the Minus button to listen to the first tone. Release it and press it again to listen to the second tone etc (3 tones)
Releasing the button after the tone has sounded will automatically set that tone.
SETTING THE MINUTE MINDER.
Press the Minuter Minder button and either the Plus or Minus buttons simultaneously to set the time.
You can cancel the timer at any time by setting it back to 00.00 by using the Minus button.
After setting, the display will revert to the time of day, but by pressing the Minute Minder button again, the display will show the remianing time.
If you want all the information, then it is best if you supply a vaild email address and this will give you access to my BT Digital Vault, where you can have a complete copy of the handbook that I have scanned in.
8helpful
2answers
Manual for Stoves EL716 oven
I have a Stoves Newhome EL716 double electric oven and last night, it just lost all power and stopped working - no grill, oven, lights, clock or anything. Can anyone tell me what this could be please? Thank you.
BROKEN GLASS ON OUTSIDE OVEN DOOR STOVES S5 600MF
You can normally replace the outer door glass independently of any other parts.
Try-----www.espares.co.uk
Plz rate my solution.
Thanks.
Instruction manuel required for stoves 720ef
I have a user guide and as I said on another post I will try and scan it so that anyone can have a copy. In the meantime, is there anything you need to know?
Top Stoves Ovens Experts
ZJ Limited
ZJ Limited
vince
Are you a Stoves Oven Expert? Answer questions, earn points and help others
