I do not know what to do
SOURCE: cd player says bad disc
Before you go and spend all that hard earn money, buy a CD player cleaner at Radio Shack, or The Source if your in Canada.
I believe there in the clearance bin most of the time for $4.99 if it's your lucky day.
Good luck and hope this helps.
SOURCE: '05 Mercury Monterey automatic doors not working.
This Should NOT Have Happened from Battery Change, But You Now Must See the Dealer to Reset FOB & Lock System they have to Connect it to A Scanner to Reset it
SOURCE: liftgate on van not working at all
There are 2 support shocks that support the lift gate. You need to replace them. One or both of them are no longer supporting the door. Your local auto parts store will have them in stock. Compare prices with competitive stores, prices vary depending on where you purchase them from. It't really easy to replace them.
SOURCE: Keyless Entry keypad code for Mercury Monterey?
Actually, if you look under the dash board, near the steering column, there should be a box that has the code printed on it.
SOURCE: where is egr valve on 2004 mercury monterey mini
You can get the EGR Valve for $80.00 OEM Motorcraft
Part, on the internet and install your self
The code better be for an EGR Valve issue or
be having issues going up hill under a load or
that isn't your problem
