I just bought my 2007 bmw 318i, and I just realise
I just bought my 2007 bmw 318i, and I just realise that, on the dashboard it doesn't have the Middle display, where you see the clock, and weather temperature. Is that normal?
That means a fault code has been loaded into the computer memory. You will need to connect a scan tool to the ODBII port and read the code to determine what is wrong.
you didn't say weather it was automatic or standard ...what year is the car and if it is standard is it going into the shifter gear position but just not engaging when you lift the clutch or is it not even going into the slot when you push the clutch down
If you've tried every which way.....the clock is broken. Included in everywhich-way would be the correct way so that didn't work? Cell phone has a clock on it.
there should be a dial to control the center vents. i believe its in between the vents or just below it. it should have blue and red marks on it. move the dial towards the blue indicator and the air should now be cool. in cold weather, move this dial towards the red indicators for warm air. you can adjust temp at these vents by moving the dial between red & blue.
