The combi preset are all out of tune need help restoring them back to factory settings or help into programming them into the right keys that i play in. the program drum kits sound just fine it's just my Combi presets that are all out of wake and sound terrible.
SOURCE: need to replace black keys on Korg triton
Typically lots of screws to remove. Be careful unplugging any ribbon cables. The cables are easily damamged by exerting force on just the edges.
Have new parts available BEFORE taking it apart for repair.
SOURCE: Broken Triton push button
I am not familiar with your exact model, but if the plastic "hinge" for the button has broken, it is possible to "fix" it. This is not a DIY repair though. Can you tell me where you are located so I can perhaps suggest a repair location?
Thanks,
Dan
SOURCE: I bought an Alesis SR-16 drum machine from an
click this link directly
Download the complete
user guide (490 Ko)
---- the link is of the user and trouble shooting manual.in that all the possibilities which can be done are mentioned.you can try all the possibilities one by one.
and yes you can transfer data from one sr-16 to another sr-16 .first you will have to tranfer the data from sr-16 to your pc.then connect the another sr-16 and transfer the data to the erased sr-16.
click the link and check out the possibilities.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
SOURCE: hohner symphonie D98, no key board sound
Look for an exploded electrolytic capacitor. They amke a pretty loud bang and make a visible mess. CLEAN any residue when restoring.
SOURCE: korg pa-50 no sound from right speaker but has sound from left
Several things to check:
If the speakers are cut off when externaal cables are connected to line outs, possibly the jack sensing switch for the right channel thinks that a plug is in there... you might cycle one in and out to see if that might fix.
Another thing is they LIKELY have a PAN control setting and it might be set full left. The external MP3 would NOT be under PAN control, only the keyboard voices would be affected by it.
