Can't find connector. is is all one long line?
You have two choices, either replace the whole line, or just cut the bad part out with a tubing cutter, then purchase a pre-made line the same size & length that you cut out, you can take the old line to the auto store & match it. While your there, you also need to couplers, which are female on both ends and 2 male connectors that will fit into the couplers you just bought.. Now you'll also need a double flaring tool (cheap at Harbor Freight).The brake line that's still on the car, you want to dry & either emery cloth or steel wool the ends where you made the cuts. Now slide 1 male connector on each side, then double flare each end of the tubing. once that's done you can put your new female couplers on each end, then connect the new length of tubing you just purchased to both couplers , the new tubing already has new male connectors , and is already flared for you. Not a hard job if you have the flaring tool. good luck. Don't forget to bleed the system when done.
SOURCE: Nissan Frontier torsion bar replacement
well it depends how you want to adjust it, if you want to lower it, back out the screw on the torsion key a couple of turns. raise, screw it in a couple of turns
SOURCE: 1998 nissan frontier 4x4
Well since the lights are controlled by the OBD (on board diagnostics), you'll have to reset it. You may be able to do this by simply disconnecting the battery for a few hours. However, a lot of newer vehicles have electronically locked radios which require the manual to be able to be re-enabled.
I'd check out the radio before disconnecting the battery.
The only other ways are to physically disconnect the lights in the dash or get someone with an OBD reader to clear the codes.
SOURCE: 1998 Nissan frontier: where is the ignition coil?
the coil is inside the distributor under the cap.
SOURCE: replace seat belt on 2000 nissan frontier
Should be a T50 or T55. Should have a cover over the bolt. Remove the cover, and remove the bolt.
SOURCE: replace tailgate handle on 1998 nissan frontier
On back of the gate, you can remove screws that are along the edge of the trim and then gently pull back on the trim as there will also be retaining clips attached and you don't want to break them. Once the trim is off, you can access the screws securing the tailgate handle to the tailgate
