Epic View 550 Treadmill Logo
A
Anonymous Posted on Aug 17, 2014
How to remove cover for epic 550 - Epic View 550 Treadmill
1 Related Answer
Anonymous
  • Posted on Jan 03, 2011
SOURCE: I am having trouble removing
If you lift your treadmill deck up, you will find 2 screws underneath, on the side, towards the front. remove them and that should do the trick.
1helpful
How do you change walking belt on Epic View 550
Heidi, There will be quite a bit of disassembly required to remove belt, I have attached your manual, which shows an exploded view showing what has to be removed to access rollers and remove belt. you may get away with dissembling/remove front motor cover,remove rear roller and front roller.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://pdfstream.manualsonline.com/d/de84f386-3308-4d84-a2ed-a52898e55aa5.pdf
Treadmill Walking Belt Installation Video by Treadmill Doctor
How To Remove Replace Treadmill Belt and Deck Green Fitness Company
Why doesn't it start?
epic view 550 treadmill video 2 - YouTube
? 2:08
https://www.youtube.com/watch?v=fSIuoh_bZN4
Mar 9, 2010 - Uploaded by Epictreadmillowner
epic view 550 treadmill video 2 ... ICON Canada doesn't really support this and the independant technicians ...Epictreadmillowner 1,181 views.
Epic View 550 Treadmill Review - YouTube
? 3:02
https://www.youtube.com/watch?v=kNiFOcrV9r4
Nov 29, 2012 - Uploaded by Treadmill Review Guru
... .com/epic-treadmill-reviews/epic-view-550-treadmill-reviews-ratings/ ... Nordic track has the track and google maps by i-fit you can download and run anywhere ... The review says it doesn'thave the track/lap but it does.
Epic View 550 Treadmill video 3 - YouTube
? 1:59
https://www.youtube.com/watch?v=YjqgZS-1qlw
Mar 11, 2010 - Uploaded by Epictreadmillowner
Epic View 550 Treadmill video 3. Epictreadmillowner ... I have had 3 different console units, and now the tv doesn't work either!
Epic View 550 Reviews - MyTreadmillReview.com
mytreadmillreview.com/epic-view-550-reviews-2
Epic view 550 treadmill
RUN the software calibration, and test the machine
God bless you
Console epic 550 treadmill
adjust the REED swtich, test it for open or faulty, clean it , and tight the plug very well. see the diagram attached.
Plug the ribbon cable for keypads very well, and clean it.
God bless you
Everything works on the display but when you start the track it doesn't move. If you start walking on the track it will dsiplay your speed but not run by itself
Remove the front cover and check to see if the RED led is solid.
4 x screws on the front and two underneath the belt to the sides.
4helpful
3answers
I am having trouble removing hood/motor cover on Epic 550 treadmill. I have removed 4 - 3/4" screws from front panel and 2 - 1/2" screws from underneath. Still feels locked on. Are there other...
I am trying to take the motor cover off to replace the motor belt. I have removed the screws in the back panel, but the cover still appears to be in a bind and I cannot find any other attatchments in the...
There are 2 more screws located on the bottom side of the cover. You will need to fold the treadmill down to the ground, console should fold down on top of the walking surface. This will expose 2 holes close to the front roller bottom. These screws are phillips head and need to be removed as well. This will free your cover allowing you to remove it.
How do I remove the cover to replace the motor belt?
There are 3 screws across the back of the cover and then there are 2 more screws located on the bottom side of the cover. You will need to fold the treadmill down to the ground, console should fold down on top of the walking surface. This will expose 2 holes close to the front roller bottom. These screws are phillips head and need to be removed as well. This will free your cover allowing you to remove it.
I put it "up" for storage and now I can't get it down to use... Epic View 550
push it forward before trying to pull knob and make sure the incline is at the lowest level.
Top Epic Exercise & Fitness Experts
ADMIN Andrew
ADMIN Andrew
Sportsmith LLC
Sportsmith LLC
Don A
Don A
Are you an Epic Exercise and Fitnes Expert? Answer questions, earn points and help others
