Where can I download the manual for this watch
See if this is it (but you may have to increase the % to read it)... http://www.casio.com/products/archive/Watches/G-Shock/MTG900DA-8V/
Try Google.
SOURCE: need too set time on my g shock casio watch
Press Adjust and hold until blinking city appears.
Press Mode until DST appears flashing.
Press Recieve until mode that you want appears ON OFF AUTO
Press Adjust until not blinking city code.
SOURCE: Lost the manual. Son reset watch. I've reset the
go to www.casio.co.uk go to support(methinks??) click on watches and put in the model number (the one you posted) and download the PDF manual relating to your watch (you will need adobe reader free download to read PDFs), this will be the full manual, once you figure it out DST will have to be on, as its summertime of course. ( i bought a wave ceptor for a fiver because the guy who had it didnt know how to recalibrate it after a battery change), a quick gander at the online manual put it right, there shouldnt be a problem setting it up again, good luck
SOURCE: Lost manual for watch
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals. Rate me, please.
SOURCE: manual for watch casio wva-105h
Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals. Rate me, please .
SOURCE: casio watch 3793 cannot change time
the best you can do follow these steps:
lests say
the top left button is a
the lower left button is b
the light button is c
and the lower right is d
to change digital time, when in time/date mode hold a untill seconds start flashing. then you can change the seconds. hit d do change seconds.
then you hit b wich brings yyou to Daylight savings, change with d
then hit b to change to hours, you can go up and down digits with d and C(LIGHT) then hit b to minutes and so on.
then hit a once to confirm and again to toggle from date to time
for analog time changing:
in time mode press a six times until it says: "h-s"
then hold a until the display flashes then press d for every minute you want to skip, you can also hold d and then press c it automaticly starts changing then hit d to stop(and maybe correct with a couple of "d's"
hit a to confirm.
there you go
http://world.casio.com/wat/download/en/manual/
Use this page to download a copy of CASIO watch manuals in
PDF format.
To download a PDF file, enter the four-digit (or three-digit)
module number marked on the back cover of your watch.
PDF format.
